I'll vouch for Malkoff he is the Tops as well as his products. They are not cheap but they are also each hand built and his standards are very high.
I had my seoul drop in lit up for 2 hrs straight and it was not even warm. Great light, plus 6 hrs runtime on 3 D batteries :thumbsup:
:thinking:
OK, now I am confused - these general problem with drop-ins for Mags is heatsinking - getting the heat generated away from the LED. The Malkoff drop-in addresses this with a large copper heatsink that fits against the inside of the light body - and so should make it warm?
Unless the heatsink spreads the heat out so much that there is little overall temp. increase in the body?
I assumed that if the light body was warm (for high output LAs) then this indicated that the heatsinking was good?
Now, with the Terralux 6EX, there is no direct heat transfer path, just the small screw on part, which acts as a heatsink, and as such I would not expect the light body to get warm. As a result the 6EX runs at lower power than the Malkoff.
Yours
A bit confused
