ti-force
Very nice review.
Thanks
.:welcome: And thanks for the kind words; I'm sure everyone appreciates that.For a beginner in this new and exiting field it is pretty hard to get reliable product information. LED lights are for example advertized as 900 lumens, when they are really more like 200 lumens. I would therefore like to thank you all, and CPF, for your valued input and info.
It would be nice to have a "most read" and "most active" info on the CPF web site in order to know what the buzz is at the moment for those who are not frequent readers.
We encourage you to hang around frequently and get sucked in like the rest of us. Misery loves company you know 😀. j/k, but once you really get sucked in, you'll be hanging out pretty often.
I am looking for a replacement for my trusted Fenix TK11, used mostly as a weapon light. The replacement should hopefully be of similar size but double the output. Size and weight are an issue but so is also the light output. The Maelstrom looks promising, especially the s12.
I think the S12 will be larger in diameter. I don't know if that matters to you or not.
The discussions on CPF can be confusing for beginners.
It can be confusing at first. There's a LOT of info on this forum, and it takes time to learn the ropes (again, this is why we encourage you to hang around more 😀).
Take this discussion as an example, The Tiablo A9 has a higher lux rating than the G5 both at 5 and 1 meter. But it is obvious from the pictures that it has much lower output. It would have been nice to have the lumens for comparison.
Ask and you shall receive 😀:
Tiablo A9 XR-E Q5 SMO (smooth) Reflector OTF lumens:
2- CR123 Lithium Primaries:
1 sec__________186.7
30 sec__________178.2
1 min___________178.2
2 min___________175.8
3 min___________175.8
Lux readings are taken to show the amount of light hitting the area of a surface. My light meter has a sensor that's about 3/4" in diameter, so the light that puts the most light on the sensor will have the highest lux reading. The high lux numbers are mostly due to light being focused tighter (reflector design, size of emitter die, emitter design, aspheric lenses etc. The tighter you focus the light , the more light you have hitting the surface area of the sensor. Think of it like a water hose with a nozzle on it; if you adjust the nozzle to the point where all you have is water spraying out everywhere in front of you, you won't be able to spray water very far because it's not in a tight stream.
If you adjust the nozzle to spray a tight pattern, you have a tight stream of water that can reach 15...20ft or so. Does that make sense? Also, a light that produces more lumens will cause the lux numbers to go up (think spigot barely turned on vs turned all the way on), this is one reason why it's best to take lux readings at 5 meters or greater distance and calculate for 1 meter lux. Another reason is the fact that the beam has spread out more at a distance of 5 meters vs 1 meter, which is more accurate. If I were to take lux readings at 1 meter, the readings would be exaggerated because you have a higher amount of light hitting the surface area of the sensor. If the light puts out a lot of lumens, the lux readings will be exaggerated even more. Does this make sense?
), several Fenix lights, and a couple Surefire G2LEDs with the TNVC dropin for carbine mounted weaponlights.
