Help Support Candle Power Flashlight Forum
Put My Order In This Morning And It`s Been Shipped!!!! :twothumbs
The Quark Turbo should fit that bill just fine.
The runtime is roughly double (on high) that of RCR yet they hold their regulation the whole way, has this got something to do with the voltage and current draw being higher with 2xRCRs over an 18650?
........ I definitely wish that Turbo was an option in the "L - M - H" mode. It's incredibly annoying having to switch back and forth between modes just to access Turbo versus L-M-H.
My Throw measures (lux) are typically taken within the first 30 secs after ignition. In rare cases (i.e. some high output, multi-emitter lights) where there is an initial drop-off followed by flat regulation within a min or two, I will wait for the regulated level (and note such in the review). But as you notice here, the light is direct-drive on max on 18650, so there is no point in waiting - it does not reach regulation.Judging by the tables and graphs it appears that the 18650 cannot maintain full output for very long; you've got about 2000 less LUX in the table with 18650: how do you measure this, is it after a few minutes once output has settled down?
...It would be infinitely better if these high-end lights would come out with fully programmable UI's, that could (with small USB-type cable) be totally customized to each user's preference. I gotta believe this is right around the corner........
The "4 turn" method of switching between "sets" seems cumbersome, and requires two hands, and like others have noted, I'd like to see the Max setting on the same "set" as the lower outputs. Additionally, the light's incompatibility with 18650 flat top cells is another bummer. I don't want to have to find and mess with a magnet, and the commentary in another thread that it "should work" is not confidence inspiring.
But the UI and 18650 flat top things are a deal breaker for me. A few levels accessed by simply turning the head would be awesome, like the U2 for example. Max>hi>med>low>moon>strobe. I'll be watching, though, for whatever else 4sevens has in store for us.
Now onto High mode, it appears that again with the 18650 the light doesn't maintain constant output, rather the output slowly tapers off as well.
Does it maintain regulation fairly well (appears to do so for ~120 mins), and maintain brightness most of the time only to taper off slightly at the end to let you know it's running low or is it always decreasing like Max but not to the same extent?
I'm pretty sure I understand why the runtimes are longer, but it was just confusing to see the output dropping with the 18650, which to be honest I thought to be a better cell. I'm new to Li-ion and I'm just trying to work out if I want RCR or 18650s as it's also going to factor into a few other purchases over the coming months. I know I'll eventually get both but for now I'm just interested in the best for this light.
Also, is it safe to assume most primary CR123s will show similar runtime etc to the Duracell ones?
powernoodle said:The "4 turn" method of switching between "sets" seems cumbersome, and requires two hands, and like others have noted, I'd like to see the Max setting on the same "set" as the lower outputs. Additionally, the light's incompatibility with 18650 flat top cells is another bummer. I don't want to have to find and mess with a magnet, and the commentary in another thread that it "should work" is not confidence inspiring.
snala said:I agree. Dealbreaker for me is when used on Max this is effectively a 1 mode light and then Max/Hi are both not regulated on 18650 either which you need to use to get decent runtime.
