Could anyone please share a side by side picture with the MiNi CR2 and/or Fenix E01?
I added a few extra lights to the picture:
Written by Batang Regla on 12-22-2010 03:20 PM GMT
Hi Selfbuilt,
I saw at 4sevens the new revo ss s2.
Comparing it with an preon 1 titanium s2, is the difference the revo being ss and preon 1 titanium or is there much more ?
Written by Ice on 12-23-2010 06:20 AM GMT
As you can easily see on 4Seven's homepage the "Preon 1" has a completely different body than the "Preon ReVO"...
Preon 1: smooth surface
Preon ReVO: knurled body
Written by selfbuilt on 12-23-2010 08:50 AM GMT
Yes, and quite a different circuit. I particular like the apparent current-control nature of the ReVo (i.e. no PWM). Yes, and quite a different circuit. I particular like the apparent current-control nature of the ReVo (i.e. no PWM).Ice said:As you can easily see on 4Seven's homepage the "Preon 1" has a completely different body than the "Preon ReVO"...
Written by carrot on 12-23-2010 08:52 AM GMT
It also should be noted for interested parties that the Preon ReVO is NOT to be used with Lithium Ion (10440) cells. You WILL burn it out! It also should be noted for interested parties that the Preon ReVO is NOT to be used with Lithium Ion (10440) cells. You WILL burn it out!selfbuilt said:Yes, and quite a different circuit. I particular like the apparent current-control nature of the ReVo (i.e. no PWM).
On the other hand, the Preon 1 can be used with 10440 just fine.
Written by Batang Regla on 12-23-2010 04:49 PM GMT
Thanks to you ice, selfbuilt and carrot.
Will buy the revo ss s2.
Thanks Unforgiven, thats the kind of answer I was hoping to hear.One of my SS versions went through the heavy wash cycle with a double rinse and spin with no operational or noticeable moisture problems. It has also survived downpours and being dropped in mud puddles. A rinse under the tap was all it took to clean it off.
Edit: Samy, the Karus is an obvious rip off of the Revo as is some of it's other designs. I too would like to see the return of the Revo.
