PlayboyJoeShmoe
:sigh:
Help Support Candle Power Flashlight Forum
(No desire for a AA-2.) 😗Yes, the Q123 and QAA use the same holster. Because there is a fair amount of soft velcro on the inside of the closing the flap, it is able to accommodate the longer QAA and still close.How many sizes of holsters are there? My prime concern is if the AA and 123 holster are the same size.
Thanks for providing the link Moonshadow. I don't know yet if David plans to send me any tactical versions to compare, but I would expect output levels and runtimes to be the same for the regular and tactical versions (i.e. differ in their UI and forward/reverse clicky).The description of the Tactical UI is on the 4Sevens thread here:
http://www.cpfmarketplace.com/mp/showthread.php?t=196499
That's a good point Andrew.My memory often fails me, but it seems that most if not all multi-level AA lights I've experienced have had very different output figures, through all levels, depending on whether they were fed NiMH or 14500 cells. The Quark, OTH, has the same output through all levels, except for the markedly different figures on max. Is this an unusual attribute or are there many other multi-level AA lights that also have it?
Truth is, there are currently relatively few multi-level 1xAA lights (i.e. 3+ modes) - most are either 2-stage or continuously variable. And of those that are, fewer still accept both 14500 and AA. At the top of my head, the only ones I can think of are the Fenix LD10/L1D, Olight T15, Lumapower Connexion X2, and Zebralight H50. The Fenix lights are mainly direct-drive on 14500, so that's out. The other 3 all have slightly higher outputs on 14500 than standard batteries, on all levels.
Of course, it's not an issue for the continuously-variable crowd - you can simply adjust down to an equivalent output level to suit your needs. But the Quarks are the only defined output lights that I can think of that keep all output levels but max regulated to specific outputs on all cells.
Thanks for stopping by David - I'm sure everyone appreciates the update.Selfbuilt - thanks for running the graph again. We've found these to be a small group of them. One of the components were lower spec than what we ordered. The parts supplier snuck in some other parts than what we ordered.
Needless to say, we won't be sourcing from them again.
About the Q123-2's unless you use rcr123's they will work fine with primary cr123a's. If you use rcr123's and are concerned, we can exchange the head for you at no charge. Theres not a way to test or determine this from the serial number. If you just use two cr123a's, you shouldn't be affected at all 🙂
Been away for a while but it's nice to see that you still are keeping up the great work, Selfbuilt.
EXCELLENT review!
And am I the only one who's surprised that the Quark AA seems to be the new king of the hill of AA throwers?
😗The Jet I Pro v3 with SMO reflector is a slightly better thrower than the Quark AA. But the Quark has a much wider and more useable spill as well as a ring-free beam. The Quark is still a very competent thrower, however. :thumbsup:
Hi, thanks for another great review!
Just a quick question (I'm quite sure it's a stupid question😳, but I'll ask it the same😉):
Would I burn something if I used the 123-2 head (9v) with the 2 AA body tube and 2 14500 cells:devil:??
