Help Support Candle Power Flashlight Forum
darmawaa, they were max. settting, both were near 2.8A current draw.
Thanks kks.
clumma,
Here is actual measurement from the tail of body & 18650 negative terminal.
4.18V current draw 0.09A, 0.78A, 2.75A
4.08V current draw 0.08A, 0.63A, 2.3A
4.04V current draw 0.08A, 0.63A, 2.24A
SST-50 GH102 brightness is very close to MC-E M bin. But the volt-in is slighty higher than Cree.
Will ship next 24hrs.
:thanks:
Good question! clumma
According to the spec., GH102 is Minimum Flux 425(lm) @ 1.75A.
That was the best bin I could get at that time. 😉
PhlatLight SST-50 devices are production tested at 1.75A. The
values shown at 5.0A are for additional reference at other possible
drive conditions.
For more details:
http://www.luminus.com/stuff/conten...2_sst_50_w_product_datasheet_illumination.pdf
From the first post, you will see:
LED: SST-50 GH102
Driver: 2.8A max 3 mode with memory, 5%, 30%, 100% brightness, no Strobe or SOS
Battery: any 18650 protected or not.
Reflector: Metal Orange peel.
Lens: Sapphire crystal
Beam pattern: Perfect hotspot, no more donut or dark cross.
Change mode by switching off & on with reverse clicky.
Dimensions : HAIII= 23 x 120mm
Weight w/o battery : Body= 66g
It can accept any type of 18650 battery, protected or not.
Thanks for your support!
GH102 min. 425 lm, max. 500 lm
From the LED should be close to 700 lumens @ 2.8A.
The Unscientific estimation:
Runtimes 2400mA : 5%~30hrs, 30%~3.5hrs, 100%~55mins.
If on 100% for more than 2 sec., (memory for max already)
First click still max, 2nd click is low, 3rd click is mid
I mean "click" is half press the switch only, not fully push the switch till end and lock.
Reverse clicky is easy to change mode.
Max, Low, Mid, Max, Low, Mid, Max,..................
Actually, I willl recommand "Protected" battery, much more easy to handle.
You have to take great attention to use unprotected li-ion.
4th run ciruit do have low voltage warming, when voltage drop lower than 3.0V, it will flash every second.
I found this from an other forum : http://my3c.com/D5/viewthread.php?tid=8749&page=3#pid57701
SSR-50-W65S-WH-G3 vs MCe K bin
