modamag
Friends, you probably have seen my The "Elephant" and the "Mouse" thread. I cram 4x 18650 into an FM fatbody (aka Elephant) using a custom 4S1P power pack. It was a PITA to make the pack. I had to provide individual leads for cell balancing. It was a good thing cause my Triton couldn't charge 4S
Anyhow, I'm in a quest to make a battery adapter that will allow the user an easy method of disassembly and an easy way to reconfigure the adapter to his/her own individual need.
Myself being an LED guy, typically will need high voltage and does not care much about current since it's relatively low (<3A). But my friend JimH on the other hand needed both high voltage and current with the special need of dropping one or two cell easily.
(Why would you ask I help JimH? Well to keep the game incan vs LED fair, even though the use of OSRAM have pretty much increased the race margin by 1500 lumens. Anyhow this lead to another long time debate and struggle to be told in another thread.)
So here's my plan. Create a battery adapter that will have <0.5 Ohms resistance from anode to cathode and with the versatility of making the following configurations.
3S1P + 1x dummy ==> 11.1V
4S1P ==> 14.8V
2S2P ==> 7.4V
3S2P + 2x dummy ==> 11.1V
4S2P ==> 14.8V
5S1P + 3x dummy ==> 18.5V
6S1P + 2x dummy ==> 22.2V
7S1P + 1x dummy ==> 25.9V
8S1P ==> 29.6V
Plus any other configuration you can think of with the use of dummy cells.
Note 1: 18650 are used for maximum power density and discharge capacity.
Note 2: "S" indicate # of cells in series while "P" indicate # of cells in parallel.
Here's a 3 yrs old design revised to accommodate the need. Any recommendation to improved upon the design are more than welcome.
I need 3x units. One for myself, two for JimH. Anyone interested in producing these? I'm too lazy these days to make anything, but I'll if I have to.
4S1P ==> 14.8V
2S2P ==> 7.4V
4S2P ==> 14.8V
8S1P ==> 29.6V
