5 XRE dive light
H20doctor
seattle
I just finished this light for a dive friend here in the Puget sound .. here are the specs
Deal lens http://www.dealextreme.com/details.dx/sku.26127
stuffed into a 2 inch ABS connector from Home Depot
I used the original driver
Runs on this battery Pack http://www.all-battery.com/84v5000mahflatnimhbatterypack11346.aspx
the light has 5 modes , High , Med , Low , stobe, and SOS ....Burn time ?? havent done one yet ... I did run it for 2 hours on 2ea ( 3.7 volt 18650 3000ma ) for 2 hours... starting voltage was 8.0 volts...ending voltage after running for 2 hr was 7.0 volts on the 18650 ...the cost to build this whole light was $115.00 american... total Build time was 3 days ... The light uses a Reed switch which is mounted in the light head, and turns on by 2 magnets in the goodman handle ... to turn on the light you simply twist the light head
That depends on what type of reed switch.. ? I use a glass reed switch and it Mounts inside the light with silicone I will post a picture
Nice! More details please!
How is the light head mounted to the Goodman Handle (that allows it to turn)? It's not screwed in I take it.
Where did you get or how did you make the Goodman Handle?
What is the cannister made of and how is it sealed?
The cannister looks taller than the batteries would indicate?
It looks like it is mounted with "bungie/elastic" (i dont know the exact english word for it) is this correct and does this give a secure connection?:thinking:
Greetz Johan
The Handles are easy to make just bend thin stock alumin .. The top is cut from a piece of Black Plexi glass.. I use shock cord, or 1/4 Bungee .. I will get pics up in a day or 2 Of the Guts of the Light head , the reed switch, Beamshots, and the Battery Pack .. Stay tuned
the tree is 300 feet away
Wall is 3 feet away
Glass Reed switch .. 50 cents each
Goodman Handle with 1/2 inch wide alumin... and Bungee
