Behold, the 5W sammich /ubbthreads/images/graemlins/cool.gif
top view:
Side view
Beam pics against MMQ3 (madmax at the top, BB at the bottom)
Now, the comparable mod using other host:
My LX mod: (still compared to MM btw)
Notice the difference in brightness between the 5W sammich and the 5W LX. That is because the sammich was only supplied with 2AA while the LX got 2 123 battery. There is also optic issue, but that is not the primary cause.
There are lots of problem with this set up, like heat issue, runtime, etc. Btw, this thing fall out of regulation from the start, as there is not enough voltage to supply the required power to the sammich.
In conclusion, i think 5W sammich is not all that worth it. Lots of issues for the modder to handle and simply, not worth the result IMHO. /ubbthreads/images/graemlins/frown.gif
