We finally had a chance to get out and do some long range beamshots. This time we used a pipeline channel cut through a near by National Forest. It was nice and dark out there with no ambient light to worry about. We ended up doing shots at 625m. We had intended on doing some a little longer, perhaps 800m or more, but we had rain in the forcast and the longer the shots the longer it took to setup. I already had to tote about 65lbs of lights, stands, cameras, tables, two-way radios, etc. across this pretty hilly pipeline stretch. Perhaps next time when weather isn't pushing us we'll do a even longer shots.
Now I first have to say it was pretty hard to aim the lights perfectly at this distance. There was a TON of crap in the air and many of the lights were really lighting everything up stopping me from aiming perfectly. I could see the target with most of the lights, but with some of their spots being pretty big, the aim wasn't perfect. We tried, but were only human.
Now this time we did the shots with two camera's. I was back at the 625m point and my brother was up much closer at appx 75m away from the target with his camera. My camera for the full 625m was a Canon T3i set at F5.6, ISO 800, 1.0sec exp, auto WB, and set at a 35mm focal point. Brothers up close was his Canon SL1, set at F5.6, ISO 1600, 1.0sec exp, auto WB, and 37mm focal length. We tried a few out focal points, but these seamed the best choice.
Oh, the target itself was a 6ft x 4ft flat white painted sheet of plywood attached to a post in the ground. Bigger would have been nice, but this was about 210m from the truck to begin with. The target was position on a slop going up hill, so it add the gassy back ground which we figured worked pretty good.
So here are the contenders -
Now the shots done at the full 625m. Again, sorry about the aim on a few. -
X40VN -
SP03 -
HD2010 -
T08 -
BTU-DOMED -
K40VN -
TN31MB -
X60VN -
TN31 -
BTU-DEDOMED -
XSEARCHERVN -
TN31VN -
K50VN -
TK61VN -
Now for the shots done up close at appx 75m. And again, sorry about the aim on a few -
X40VN -
SP03 -
HS2010 -
T08 -
BTU-DOMED -
K40VN -
TN31MB -
X60VN -
TN31 -
BTU-DEDOMED -
XSEARCHERVN -
TN31VN -
K50VN -
TK61VN -
X40VN -
SP03 -
HD2010 -
T08 -
BTU-DOMED -
K40VN -
TN31MB -
X60VN -
TN31 -
BTU-DEDOMED -
XSEARCHERVN -
TN31VN -
K50VN -
TK61VN -
X40VN -
SP03 -
HS2010 -
T08 -
BTU-DOMED -
K40VN -
TN31MB -
X60VN -
TN31 -
BTU-DEDOMED -
XSEARCHERVN -
TN31VN -
K50VN -
TK61VN -
