Well that being said my plans are for one of the 6p I am going to run the aw imr batteries that was recommended in one of my other post the second one I am going to bore out to accept an 18650 as I have 6 of then from a lap top the lamp I have now says it's rated for 980 lumens and is a 3 mode xm l2 U2Since you said bright and reliable (and I'm glad you did) I will add that the type of batteries you use will factor into the equation if you're going with any of the really high-powered drop-ins.
If you're planning to go with CR123 primary cells then I would advise you to stay below 600 lumens or so for your drop-in. That's not to say something more powerful won't work, but the battery reliability (and runtime) comes into question after a certain point. For the record, 600 lumens is still a ton of light, especially if you're upgrading from an incandescent 6P.
The super high powered stuff requires lithium-ion rechargeable batteries and probably boring your 6P so that it will accept larger cells.
So I picked up my 2nd surefire 6p and was wondering what's the brightest reliable drop in for this light thanks
Yea I just looked at the trip led drop in and omg this is going to get exspensiveIs there a budget for said high powered drop-in? It's quite easy to spend over $100.
What beam do you want?
I recently ordered a sportac xml-2 dropin from eagletac for my 6P. I'm running it on two 123 primaries right now. The dropin is rated to 9v. I'm planning on switching to 16340s eventually. I'm very impressed with the performance. Think it set me back about 35 bucks or so.
I don't want much of a flood pattern a good solid spot would be awesome+1
Before real suggestions can be made, it really would be helpful to know what kind of beam pattern you'd like.
Options are:
Mostly throw for illuminating objects at distance
mix of throw with lots of spill
really floody with not much throw (though a ton of lumens does help some with distance)
huge hot spot with nothing that could be considered spill (typical of triples behind individual optics)
strictly flood, which is what is delivered by a mule with no reflector or optic at all
others......
That sporttac 219 triple isn't bad price at all the ones I looked at the other day 175 and up+1, my sportac 219 Triple is amazingly bright, friendly for 2 CR123's, and seems well made (although time will tell).
I live and oklahoma and thanks for the input guys I got to get some batteries ordered as the first lamp I ordered I don't thing I have enough juice to operate it properlyDo you live in the US? I've got a few drop-ins that aren't being used at the moment while their hosts are off being bored for 18 mm cells. If you're local, I'd be willing to send them to you for evaluation from an output/beam shape perspective.
Which is the more important criterion for you, output or reliability ?
If reliability is the primary factor, I would suggest a Malkoff. Although the high output and super high output versions are very bright indeed, absolute maximal output is not their purpose. They are, however, built for maximum reliability
I put in a Redilast (EDCplus.com) 3 mode XM-L2 U2 that does 530LM at 1.5A. It cost me $40 w/coupon before shipping and made my 6P something other than the anemic POS that it was, lol.
Chris
