js
LEDmodMan,
Thanks for the update!
For those of us who live in places like Maine or New York or Vermont, the only solution in the Winter is to roast under a hood which vents to the outside, or to roast with the hot air popper pointing out a partially opened window. This is what I do and it works very well. I should also mention that most air roasters rely on having the proper voltage and if your house has old wiring or if you are using a very long and thin extension cord, the low voltage at the roaster will cause it to not get hot enough to get into or past first crack.
Also, INCREASING the amount of beans roasted will actually raise the temperature of the roasting air because there is more resistance for the fan to overcome and thus the air stays in contact with the heating coil longer. So decreasing the amount of beans will actually result in a slower roast. Most hot air poppers want a 1/2 cup of green beans, but some will take 3/4 cup. In any case, the beans should be MOVING even at the begining of the roast. They don't have to move much at first, but they should move a little. Some people actually stir them at first until things get going. The toastmaster that LEDmodMan mentions above is already at full capacity at 1/2 cup and should NOT be pushed past that. However, if you can find one, a WestBend The Poppery (NOT the Poppery II, but the original) will take nearly a full cup. The Proctor Silex The Popcorn Pumper, which I use, does well on 3/4 of a cup. I actually like it better than either the WB P I, or the TM, both of which I own in addition to my PS.
