I hate to do it... I hate to turn this peace-loving forum into a conflagration where dualing opinions and points of view spill over into rancor but this is something that I think is important enough to say that I must risk it:kiss:
The JETBeam RRT01 Raptor 2020 edition is an unnatural abomination
Now, having said what I just did, I must say that it is a fantastic light and a great bargain...
Okay Goatee, what gives? How can you hold such ideas in mind; I mean, how can you hold what appear to be contradictory ideas in you great and powerful flashaholic mind?
Well, hear me out before you lock my account down or ban me from the forum!!! I beg your indulgence, I only want to share my point of view even though it may be different than yours:naughty::laughing:
My views are based on the newly added switch at the end of the light and here is the crux of the matter... when you press a switch that is mean to turn the light on, it should turn the light on. There you have it. I think that is a hard point to argue, no? It doesn't matter whether it turns the light on to the lowest, the highest or any level in between, what matters is that if you click the switch from the off position, the light should turn on.
Now, opinions probably vary on what the lowest level should be (I would say .5 lumens) but we surely can all agree that it is a design concept fail to have an on / off switch that fails to turn the light on sometimes but that never fails to turn the light off.
What are your thoughts? Is there any room for common ground or are we hopelessly far apart such that we are destined to drift into competing camps who work against one another using any means necessary to destroy each other?
Here are some additional thoughts:
- It should not be marketed as tactical unless they change the operation to be such that the light comes on at full power whenever the switch at the back of the light is pressed and the switch at the light should be a true momentary... you don't want the light to latch on when it should have gone off and you don't want to have to remember to engage in critical thinking about the lights function when you are in a situation where the light turning on and off matters.
- In a non-tactical light, the ideal switch at the end, for me, is a 2-stage momentary like Surefire uses where a short press gives you access to a low level and a full press give you access to a high level. The latching function of the Olight Warrior Mini is pretty awesome but I think I might give that up to avoid some of the troubles they are having with melting lenses and burning clothes.
- Combining the Raptors awesome magnetic level control ring with a 2-stage momentary at the tail end of the light would produce a wondrous light. The two levels should be set like Surefire's levels are on the EDCL-1T but it would allow the levels to be "turbo" (exceeding the current 500 lumen level of the EDCL-1T and 5-10 lumens... Surefire, can you hear me?
