Widsith
Banned
While playing with my Pro I've noticed a few strange things that I haven't seen mentioned elsewhere. Several people have reported the red LED flashing briefly when the light is powered off. It's been explained (convincingly, in my opinion) as being caused by the sudden voltage drop triggering the low-battery circuit momentarily. Now for the oddities: I've also noticed that the red LED will flicker when the light is switched on, in either the red or white mode. The flicker is very dim and brief, much shorter and dimmer than the flash at power-off; I usually can't see it unless I'm looking into the reflector at the moment the switch is pressed. Releasing the switch immediately after the flicker turns on the white LED; holding it a second or so longer turns on the red LED. I assume that this, like the power-off flash, is caused by the low-battery circuit kicking in momentarily.
However, sometimes -- rarely, but on occasion -- the white LED will flash at power-on. This is considerably brighter than the red flicker and in dim ambient light conditions it is noticeable even with the light pointed away from me. It doesn't happen every time, though, and has happened only when the light has been off for a while. Anyone have any idea why it would do this?
The third odd thing I've noticed happens only when the battery is very low. At this point, I can ramp the red up to maximum or the white down to minimum as usual, but cannot get into any of the strobe or signal modes. Attempting to do so just turns the light off (and if the battery is low enough, it won't come back on until I let it rest a couple of minutes). The weird thing is that by trying to get it into signal mode with a low battery, I managed a few times to get the white LED into a sort of reverse signal mode. That is, the light will go off when the button is pressed, but come back on when the button is released. To turn it off and make it stay off it's necessary to get out of this mode, by holding the button down long enough for the red LED to start ramping up. I've not been able to get it into this mode anytime except with a very low battery.
Has anyone else seen this behavior, or any other odd things (besides the usual easter eggs)?
