kengps
Here is my newly built Pocket Aspheric. I used a Tiablo A9 Aspheric lens, a shortened Solarforce L2P host, McClicky switch SF tailcap, EZ900 die XR-E R2, and AMC 4X7135 1.4A driver. The EZ900 die is responsible for a 23% increase in lux over the EZ1000 die R2's. This light is only 5.95 inches long, yet uses an 18650 battery. I did everything I could to make it as pocketable as possible. Today my AEMC CA813 light meter arrived. Measurements taken at 10 Meters. Start-up 121,000 lux. 30 seconds 117,100 lux, 3 minutes 114,000 lux. My DEFT-FTP did 131,500. Considering this light is half the size of a DEFT-FTP I'm quite happy. To minimize size and fade I built a special pill with no threading for maximum heat transfer to the body. It is a tight press fit, and I Artic Silvered it in place.
Here is a shot of the threading and pill.
Masterpiece pro1 on left (56,000 lux) Aspheric on right (121,000 lux)
Lots of testing to do with new light meter.
UPDATE 121,000 peak, 117100 after 30 seconds, 114,000 after 3 minutes. Really happy with how well the heat sink is working. Heres a pic of the Lumapower pill I built. I replaced the thin .7 mm bulkhead with a 6mm thick sink. This is 1.4 Amp EZ900 also, and I'm getting 103,000 lux with the Turbo-Force head. Too small the hot spot though. My plan is to put it in the Tele-force D-mini head. (did it. 27,800 lux) Not bad for a 3.8" long pocket light.
