JCD
- Joined
- Apr 12, 2010
- Messages
- 892
Consider the following two identical Li-ion cells:
Cell A is charged to 4.15 V. It is then discharged in a (hypothetical) light with a 100% efficient buck/boost regulator to 3.60 V, at which point x mWh of stored energy have been depleted from the cell.
Cell B is charged to 4.25 V. It is then discharged in the same light until x mWh of energy have been used. Its voltage is greater than 3.60 V (about 3.65 V?), and it should have roughly 10% capacity remaining (based on a 4.20 V = 100% capacity).
Repeat process 100 times.
Which cell will suffer the most wear? Will cell A wear faster because it is consistently discharged to lower levels, or will cell B wear faster because it is consistently charged to higher levels? Will there be any difference?
What I'm wanting to know is if the extra wear from charging cells to higher voltages wears cells quicker because of the higher voltage, or if it's because they have more energy depleted from them per charge cycle, due to the additional capacity. Does a complete discharge (to minimum voltage that leaves the cell safely rechargeable) cause more, less, or similar wear compared to charging a cell to it's maximum recommended level?
