degarb
I like the 90 degree off axis model of the Zebra light h31w, over boring traditional in line flashlights. The design allows up/down aiming in a simple elastic mount to a headband, and perhaps sticking out of a shirt pocket, in a hands free pinch. Also a small, light design allows for a good hands free edc.
Got an idea. I do have a 1a xml2 u2 drop-in in basement. I think I may attempt to make a single Zebra style light from it, using a $2.99 Harbor Freight 3 AAA 9 led tube for the battery compartment. The compartment should make a 18650 spring holder, with unscrew-able clicky, and heat-sink. I will need to knock out the 9 led part, solder/JBWeld the dropin at a 90 degrees at head, with positive battery spring on side of dropin. I got a large amount of JB Weld Original on Ebay, and a pound of heat conductive Zinc dust from amazon. I am thinking of using a old Ray-O-Vac headband with elastic for tubing where old head would sit. Also for diversity sake (the drop is probably fairly throwy enough for task-lighting in a pinch), I would add a flip over diffuser, made of flexible milk jug plastic for nightly reading.
Might just work, and be ipx6. Any thoughts?
The draw back, is the time this will take and life's priorities.
