luxlover
Banned
Hello fellow HDS/Arc LSH lovers,
My CPF buddy iocheretyanny gave me this idea, since he only has one HDS light and no Arc LSH light. What you are looking at is a novel idea, which on the surface may appear silly. But in use it is very practical, and yielded better results than I expected.
I took my two HDS lights and my Arc LSH FLuPic light, and strapped them together with a JANDD Mountaineering Co. velcro strap which I use to securely hold my hand pump onto my mountain bike's seat tube. This "stack" has a stock U60, a Seoul emitter modded U60 with a 133lm output, and an Arc LSH with roughly 54lm output on maximum. When all three lights are on maximum, the total output is about 247lm. The charm of this setup is that each light can be utilized independently within the stack, and any one, two or three may be used....or not used. The amount of light projected when all three are at maximum is amazing, especially when considering the total size of the assembly.....2 3/8" at it's widest. The beam pattern is very clean, and the three reflectors blend well in unisson.
I will be looking for a better way for the three lights to be stacked than with my velcro strap. I don't want the fix to be permanent. I use each light as an EDC and want it to be independent of the others most of the time. But as an assembly, they are ideal for when a huge amount of light is needed. Note that since each of my HDS lights has an 1/8" thick protective rubber/foam tube placed over it's head, and the Arc light does not, the fit is not what I would like it to be. For those who have three HDS lights, you will have a field day if you stack three of them as I have done. Guess what....it even tailstands! :laughing: The bottom image shows the stack the best.....
