A Tribute to Nitecore D10
Gosh...thinking back to lights past I might miss the Nitecore D10 the most. Perfect size to output ratio. Great construction, nifty switch mechanism... what a light!
Indeed. I never should have sold off my initial collection. Totally regretting it now. I'm trying to start it back up again, and though I have more models of the D10 (and EX10/11) now, nearly all of them have some sort of use or wear on them. My initial collection were all new condition lights. Oh well. Makes the chase more interesting, I guess. Thanks for bringing this thread back up.
I was looking at the swissbianco pics in this thread and remembering how I used to have a few of em back in the day. Cest la vie! Hope to grab one to fiddle around with again for nostalgia sake. Good luck in your hunt!
Stilk use mine. Led is a neutral xp-l hi.
Love mine, but last week it stopped working. When tightend down it givesnoff a brief flash then does not power on. The first time it happened it was flashing every 10 seconds but now it only gives the one flash and then refuses to turn on. Nitecore CS says it cannot help since it's not in production. I took it apart, wiped piston, wiped o ring, cleaned inside of body , tried removing the o ring, pushed around the brass ring.... nothing has helped.
Im sad at the loss of this light, one of my favorites with my Zebralight, another old schooler at this point. Any thoughts before selling for parts on EBay?
From what I've read it's not that hard to modify. Could be just to solder joint. Take it apart whatever you got to lose
No worries, I'll tidy up the thread later.
Hopefully, CPF can help get this nice torch fixed up for you 🙂
EDIT - several off-topic posts were removed, linking to a "Good Deal" that had expired
consider buying an EX11.2 model and swapping drivers to your D10. It looks like the electronics are the same, there is just a difference in the diameter of the driver, that could be adjusted.. (I have not tried yet)
the 11.2 driver has a wider output range than the 10.0 models. And the lower low of the D version on AA, is directly related to the battery voltage.
fwiw, this video showing how to remove the pill of a D10 makes the process more difficult than necessary, and does not work for EX models..
these are the techniques that work best, for me:
D10 pill removal:
It is quite simple to unscrew the pill without removing the contact ring first:
Seeking help locating Battery Springs, as used in version 10 lights.
The gold plated spring on the right is from an EX10 Ti and is softer than the nickel plated spring used in the EX11.2 models
For me, the softer spring from Version 10 lights, is much nicer to use, and it works with protected batteries. It is not necessary to limit the Piston Drive lights to unprotected batteries, when using the softer spring.
In my experience, the resistance of the piston in the 11.2 models is not fixed by lubrication of the piston sleeve.. the battery spring is the primary source of the piston resistance.
Was using my D11.2 tonight. It's one my older lights that's always primed and ready to flash. I especially like its true moonlight level.
Geoff
Thanks!
I have three of the camo lights, all unique patterns and colors, amazing how they did that.
The only problem I have had is cell length. They are very fussy about the AAA length, have to find ones that work well.
I love seeing this thread revived. Even if it's just for a little bit. Thanks for the contribution jon_slider. Wonderful post.
Zeruel. Not sure if you're still around the forums but if you see this, so you think we can somehow repost the pics to preserve this wonderful thread? I'd be willing to help with that somehow. Not sure how though.
Glad to see there is still some interest in my all time favorite light. I found a few in a drawer last week.. I need to get them out and see if they still work. I switched to an MH20 for work just because I like the extra everything, and easy charging. But no light feels so right in my hand, or UI so perfect. I wish someone would make a D10 with an 18650 but last I spoke to Nitecore, the designs are all tied up in some legal action...? Maybe someday, I can dream. :sigh:
