FlashInThePan
Hi folks! While I love my 1x123 A19-Cree-XRE, I'd love it even more if it had 2 stages. =) So I'm I'm hoping you can help me choose the right mc2es tailcap.
First, the battery issue. I'd like to be able to use primaries if possible; can this be done? And if so, will it work with all resistor values (e.g. 5 ohm, 10 ohm, etc.) or only certain resistor values? If so, which ones?
Second, the brightness. Does anyone have experience with the approximate brightness of each resistor? In other words, does the 5 ohm give about 20 lumens, the 10 ohm give about 10 lumens, etc.? I know people probably won't have exact numbers, but even estimates would help. And even comparisons to other lights would help (e.g. "the low on the 15 ohm is about as bright as an Arc AAA-P").
Finally, the purchase. I'd prefer to buy a pre-made switch (my mechanical skills leave much to be desired.) I noticed that the Shoppe sells the DIY kits; does anyone else sell these kits pre-made? (I didn't find anything on the common sites like Lighthound.) Does anyone on CPF assemble them for a charge?
Thanks for all your help!
- FITP
EDIT: I have one of the original A19-Cree-XREs, which I believe was driven really high - 825 or 917, I think (or somewhere in that range).
- FITP
