AA Flashlight (new single cell converter) addition to the series
McGizmo
Maui
Hi guys,
I have dragged my feet too long now on introducing this latest converter. I am choosing to call it the AA converter for hopefully obvious and helpful reasons. The converter is designed to function with an input voltage of ~ .8V up to the Vf of the LED or 4.5 V max. Basically this means it will work on one of my lights using either the single AA pak, 2xAA pak or the 1x123 pak provided the right battery is used. The primary goal was for it to function on any flavor of single AA battery one might have on hand; alkaline, nickel-MH, lithium or what have you. A CR123 primary is fine. A Li-Ion will work but any voltage over the Vf of the LED will be clipped and wasted as heat.
The converter is a three level converter with the same method of level change used in the 3S converter as well as the 6V buck 3 speed converter I have been building with. The output (constant current) from this converter is 15, 45 and 300 mA (low - high). On a test mule with XM-L LED using this converter and a AA Alkaline battery I measured lumens of 2,10 and 85 (low - high).
This converter is a double sided PCB in the same physical package as the other converters and it goes in the same light engine package I have been using.
Consequently the possible variations of battery pak and head that this new converter can be a part of is just more confusion for all of us!
As for possible battery pak to be used with a AA light, all but the 2x123 pak (3rd from left) in the pic below are viable.
As for heads, the light engine can be used in a Mule, SunDrop, Haiku or even Makai head.
Either the Nichia 119 or Cree XM-L LED can be coupled with this converter.
In the pic below, from L to R are an AA Mule, Haiku 1x123, AA Sundrop and then an AA Haiku.
My assistant is checking the grip of the 1x123 pak compared to the AA pak. And looking a the differences in the shot below:
I won't begin to guess at runtimes of various combinations here but I did do a run time on a Mule XM-L AA with the light turned on high and left to run:
You can see that at one point the converter dropped out of regulation for a moment and then attempted to continue on, only to drop down again to the low level. What I didn't record was the fact that this ran for quite a while before I checked on it. I turned the light off and when I turned it back on, it came on in high again and held for a while. With intermittent use and various levels selected, I think you can get a good amount of light from a single AA battery.
As far as pricing goes, the AA converter cost is the same as the 3S converter and the single AA pak is the same cost as the 1x123 pak is. I fear I am inviting confusion by calling the converter an AA converter as well as using the designation for the single AA pak as an an AA pak. :tinfoil:
But for example (and in the convention that AA designates both the single AA pak as well as the AA converter), the following lights would go for:
Mule AA XM-L - $415
Mule AA Hi CRI - $410
Haiku AA XM-L - $455
Haiku AA Hi CRI - $450
As for anyone wanting to order one of these lights, please refer to my "How to order and Policy" thread.
I should add that of course you can request the 1/4' x 20 tapped pocket clip for an additional $5 on any of these. I built myself two Mule AA's, one Hi CRI and the other with the XM-L and added the 14-20 clip. I really like these lights as I see them bridging the gap between the sapphire and the higher powered lights.
Lastly and really off the subject at hand, I want to thank you guys for putting up with me and my offerings these years! :bow:
When I was taking pics this AM of the lizard and the lights I realized how very fortunate I am being able to enjoy a work/ play lifestyle involving my interests as I do. Without your support that wouldn't be the case. As far as spelling and grammar go, there is no hope! (I just noticed the title in the graph :duck: )
BenChiew
Malaysia/Ship to Portland, Oregon
Congrats Don. Can't wait to get my hands on them. It really opens up new possibilities with the range of voltage that it handles. These are surely going to bleed those primary dry.
Not to mention the versatility of AA availability world wide. Now even my grandma can use it. :)
And you can have your choice in any of the heads and emitters too.
Two thumbs up for this.
coloradogps
Colorado
Don,
Great news here!
i look forward to getting one or two of these AA lights.
:twothumbs
Thanks,
CGPS
Silgt
Congrats, and very nicely done. Seeing myself adding an AA Haiku to my EDC duty light very soon :thumbsup:
McGizmo
Maui
Hi guys,
I think one observation may be worth pointing out here. The Nichia HiCRI has been at a disadvantage in my other lights compared to the Cree LED's by virtue of its lower current capacity. With the AA converter and a max current of 300 mA, the Nichia is on a much more even footing. It still can't compete with the efficacy of the Cree but the quality of light goes to the Nichia and for throw and a clean beam pattern, the Haiku AA with Nichia is a sleeper in my opinion.
archimedes
CONUS, top left
I am curious as to the efficiency of this driver versus the previous standard "3V" driver .... In other words, if one is planning to primarily use a 3V or 4.2V power source, is there any reason to prefer the older version ?
McGizmo
Maui
Dave MC,
Yes you are correct, $235 plus postage for a Mule AA HiC head.
Archimedes,
I don't know what the efficiency of this driver is compared to the original 3S converter is. Since the 3S is a buck/boost it may not be as efficient. However Like I tried to explain above, if your input voltage is above the Vf of the LED and presumably some overhead, the excess voltage is wasted as heat. I guess this converter acts as a current limiter at that point as opposed to the more efficient buck of the 3S. The other consideration is that the 3S converter drives the LED on high at a higher current level than this AA does. All told, If someone is planning on using 3V or certainly 4.2V power source only, I see no advantage to this AA converter. For power sources 3V and below it's a different story.
archimedes
CONUS, top left
Thanks for the explanation!
I like the current-controlled lower output modes, and the lower voltage range, of this driver .... Understandable that there may be trade-offs, though, at the higher voltage.
The Coach
New Jersey
So, speaking in terms a guy like me can understand, if I were to purchase a AA Haiku Hi CRI with a 1 AA pak ($450), I could replace the AA body with a 1x123 pak with a SF123 and it would work just as well? :ohgeez:
If so, does your assistant work on the weekend and does he (she, it??) do the packing too? :devil:
McGizmo
Maui
Hi Coach! :wave:
Yes, you can put the AA head on a 1x123 pak and use a primary like the SF123, no problem.
And no, the lizard doesn't but I do. ;)
The Coach
New Jersey
Well, it's been too long since I last said this, but get one ready, I'm sending you an email momentarily. I was thinking about ordering a light with the Hi CRI LED and this is just what the doctor ordered. One Haiku AA Hi CRI - $450, please!!! :devil:
:paypal:...............:rock:
Thanks Don. :thumbsup:
Silgt
Don, do you still offer bead blasting for your lights? Interested in both AA Mule & AA Haiku but would love to have them bead blasted if possible
Sent from my GT-N7105 using Tapatalk 2
BenChiew
Comparing the the AA XML beam with the 3S XML beam, one can barely see the lumens difference. On low and medium, I could see that the 3s is a touch brighter. On the high the difference is much lesser.
AA brings new frontiers in battery choices and at the same time, the LE happily takes a 3.2V CR123. In a pinch, you could also get light with a single 4.2v rechargeable setup.
If you have e series lights with you, this LE will compliment your arsenal.
