AA light needed with details
ledbetter
California Central Coast
As JJ Cale says, “Traveling Light” is the only way to go. Both lights work on 14500 and AA. Malkoff M30 module.
kerneldrop
South
Malkoff is the clear winner! L11’s are battery cases for my Malkoffs!!
haha, the savage of the flashlight niche.
i remember the issue with zebralight now. i read they use some weird form of pwm. i cannot. stand. pwm. is this true? are they not constant voltage? this seems to imply such. that would be a deal-breaker for me.
I can't even. I mean I can't even.
so close. but no l11 nichia means no l11. :p
After all this, I can confidently say....we all now understand why your wife gets annoyed at just your mere movement. :LOL:
luisdent
well, pwm is always a source of contention between flashlight users. so I'm not even going there. :p i find it awful in every light I've ever seen it on. if the zebralight is somehow special i might try it as long as it can be returned. but i doubt it's special.
and after using neutral leds i can never go back to cool white. sorry. to each his own. :p
ledbetter
L10s/11s were my go to gift for family and friends for a while. Now family all has at least one Malkoff/Surefire. The ladies like the colors but L3 no longer offers a rainbow assortment.
luisdent
I'm confused. the post i oinked showed pwm in zebralights,but their site claims this
  • All levels are current regulated
are they using different drivers now? is that false? is it specific to certain models? maybe i just need to buy it and test it...
Repsol600rr
You can't program it where 3 clicks is always high but you can program it where 1 click is moonlight and a double click is medium. There is a small timing component with zebralights. They are designed to work with a hold, a single click or a double click. 3 clicks will go to a strobe or blink mode and that part cannot change. So if you wana simple ui program 1 click moonlight, 2 clicks medium, hold for high. You can play around with sub modes after that which are a double click once the light is on and in a mode. To ensure you never accidentally go out of moonlight at night you program both modes in the group for 1 click as moonlight modes. That way no matter which moonlight you left it in, it will still be in a moonlight when you click it. It remembers which submode you are in so if you have 2 drastically different sub modes in 1 group you may not get the right one but you can alleviate that by programming it to either litterally only have 3 modes or making a habit of putting it in the lowest or highest submode of each setting depending on what you want it to do. It sounds complicated but it really isnt. It'll take you 5 min to decide what outputs you want, 5 more to program it, and 5 more to have it down. Also no preflash and if you can see pwm in this thing then your eyes must have the highest refresh rate know to man, but I dont think it exists in these. I do remember reading something about it in the old models. I also do not like pwm. I have several 52 and 62 series lights, ive used all the modes and I have never seen so much as a ripple.
luisdent
maybe t
hey have changed. i may give it a try.
so to be clear. my typical use case would be this. go to work, use a low/med level for computers, under desks, network closets, etc. then at home i might use it on med/high at night outside with the dog, then in bed I'd use moonlight mode. my preference would be to have a single click always go to moonlight mode. can a second single click cycle modes after that? i assume that's what you meant. click once, turns on to moonlight, click once again switches to medium, hold for a second to activate high? that sounds reasonable if so.
luisdent
i bought the zebralight. we'll see how it goes! hopefully the backorder isn't too long.
Repsol600rr
maybe t
Not quite. Once in moonlight another click will turn it off. Once its off you can double click to medium. For your use case I would program 1 click to moonlight and the sub mode of 1 click (double click once it is already on) to another moonlight. That way click 1 always gets a moonlight. I would then program a double click (from off) to be medium with the submode as a low that is >1 lumen. That way double click (from off) will get you a usable amount of light and you can use a double click (while on) to switch it up or down depending on which mode you are in. I would then have hold (from off) be a high with the submode (double click from on) be a lower high. So in function 1 click moon light. 2 clicks(from off) usable light, hold (from off) higher amount of usable light. From any mode 1 single click will turn the light off.
luisdent
gotcha. seems easy enough. I'll see how it goes. i don't need it to start in moonlight per se. i just always need to be able to get to moonlight without having it be bright first... and simple enough not to accidentally trigger a brighter mode. i promise you a burst of 330 lumens will wake my wife :p and just be annoying. ha.
woodsmith
Midwest
Well this was quite the "recommend" discussion...glad you found something and hope it works out for you!
kerneldrop
South
We know you're really special ops needing a backup option to the Elzetta Charlie.
You can't fool us.
luisdent
You can't fool us.
my elzetta is my backup edc light when i don't feel like carrying my Imalent MS18 ;-) ;-)
markr6
Yeah what a piece of junk. I had the L11C for a while with little to no use. Today I pulled it out of the drawer and dropped it about 18" onto the carpet and sort of hit the cabinet. Dead.
