drillbritz2ov
hello not seen this one before so here goes. I use a AA mini maglite as my edc which has the nite ize 1 watt led upgrade along with the iq switch upgrade ,great little torch but as you guys know if you have got wet or oily hands it can be a right pig to use with it being so smooth . So thinking cap on using what was at hand it the workshop I made the following ,I took a plated 16 mm hexagonal nut spun it in a lathe and reamed it out so it was a nice slide fit on the battery tube and then pressed it on to the knurled section until you could just see the knurling start to emerge say about 22mm from the rear edge of the battery tube ,job done . I now have a superbly balanced flashlight which you can use cigar style or full grip style with wet or oily hands and also wont roll off the bench,brilliant and for no cost apart from my time and it does not look to bad .hope you find this little mod useful been looking for something like this for a while .cheers Cliff
