Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
Ok, so it's actually here. I don't know why it took them so long to come out with it.
http://www.sonicare.com/dp/prof_products/xtreme_pro_series.asp
It makes a great companion to flashlights, because its designed for 2 AA alkalines and runs great on NiMH and it's only $30. Apparently the circuit is the same as other models using NiCd, so it actually shuts off around 0.9v/cell protecting the cells.
The charge lasts a lot longer than the NiCd sealed(which I'd guess is around 700 mAh) into usual Sonicare brushes since you can use eneloops. Not having to take the tree stump charger with you is a great benefit.
This electric tooth brush has the same function as their very basic model, the Advance. It is marketed towards pre-teens and teens, and there is a 2 minute shut off timer and nothing else but it uses a brush head for the Elite series. It's got blue dots decoration that looks like the 80s Sony logo ( http://en.wikipedia.org/wiki/Image:Sonyd50.JPG )
You'll can't charge the batteries without taking them out, but each charge should last 2-3 times as much as the usual NiCd, but you won't have to throw out the entire brush just because the battery won't hold charge either.
