My haiku wasn't operating normally for first 5-8 mins last night and then appeared to be back to normal.
My 5 days old haiku might have some problem. I wrote to Don already.
I turned it on last night and it was flashing on/off! I thought the panasonic primary was dead, I changed a fresh primary! The haiku did not response when I turned it on, 2-3 seconds later it dimmed on ( gradually from low intensity to max)! I pressed on/off for good 10-20 times trying to change light intensity! It was still in dim on mode and I could not change the intensity!
Ok, I changed to Aw R123 to check what will happen, still doing the dim on mode!
I changed to surefire e1e body and check again! No luck at all!
After 5-10 minutes numerous attempt and frustration , the haiku behaving normally all in a sudden!
My second question regarding the swapping of LE . I have Sundrop XRU Nichia and the Haiku Xml . Are the LE interchangeable ? Any modification needed
If my LE has issue, I wanna just to send the LE back to Don and hopefully he will be
able to send me another LE!
Thanks for your time and will try to update all!
I think I am natural LE enemy! I had to send my Sunwayman Mr Elfin and the jet beam tcr01 back for warranty due to LE problems!
