I recently purchased 12 accupower LSD D cells and 2 Vanson chargers. I got the chargers from battery junction. The problem with them is no matter which channel I use it seems completely random whether or not the charger reaches termination. I had a cell that never turned green, I marked it a bad cell, and moved on. Later the one's that did turn green, some of them decided not to. I put the "bad" one back in and it decides to turn green just fine. I expected if fully discharged that I may have to cycle these batteries twice, but these were fresh from the supplier, reading about 1.2v already. The ones that stayed on the charger got quite warm, and I have since learned that this probably means they are over charging. If I pull one from the green circuit, it reads 1.9V fresh off charger and the red circuit comes hot off charger at 1.8V. These #'s seem very high to me? They settle down to about 1.35 after awhile, which is much better.
The documentation included with the charger states charging D cells from 1200-11000mAh.
So, I pick up 4 Titanium brand C cells, 5000mAh. The charger works flawlessly with them. I then bought 4 accupower LSD c cells (they are 4500mAh) and I run into similar problems.
I can only conclude 2 things,
A: this charger doesn't like the higher resistance of LSD cells?
B: this charger is a piece of junk???
If I choose to monitor the charge and just pull the batteries when warm, I guess it is useable, but that isn't really realistic when it could be as much as a 10 hr charge time or more.
Oh yah, one more thing, I thought this charger was supposed to have a timer safety. Well not that I can tell, from either the docs or from function. It doesn have a 14hr timer for 9V, but they are charged by a simple dumb timer charge.
