Acebeam H50 Headlight
ca pow
Acebeam is currently showing an H50 with three options of different LED manufacturers, I'm very interested in the Nichia 219C. They are showing a price of $89.90, but also showing a "Submit Order Inquiry" button, with no order option? Am very curious to know what this means. Anyone know about this?
Ended up buying this model, it is my most preferred headlight. The three Nichia LED's are a very nice color balance, you can use one, two or three of the emitters, and can control brightness at each stage, giving a lot of flexibility of brightness and burn time.
shopping
Do you like the brightness spacing ?
Mostly am using all three emitters at once, I like the increased field of view, with each emitter engaged there is a tad better field of viewing and yet just one focused beam with a nicely diffused hot spot. As for the "brightness spacing" every setting is noticeably different, there doesn't seem to be any replication. If I were reading while camping using a single emitter on low would be a very nice reading light.
