windstrings
No doubt, if I remember right we're talking about 7000 cells!
Help Support Candle Power Flashlight Forum
Done and +1 to the ranks of the K60 owners: me. Quick writeup on first impressions:
After playing with it for a little while, EVERY OTHER LIGHT I have looks dim. Even on partially depleted IMR batteries, which don't run the 5K level at full blast (I haven't had time to charge them), the K60 is VISIBLY brighter than the TK75 on fresh cells. The ring UI is so much nicer, and makes the K60 a surprisingly practical light: if you set aside the size, coming as I do from the days of much larger lights (eg various Maglites of considerable length), it's actually really quite useable.
Firefly mode is very charming - amazingly, it is dimmer than all other lights I have (various SF, Fenix, and an Olight). Perhaps this is my first true firefly light.. ironically, my most powerful as well. I know, right?
High mode gets really toasty, really fast: I was thinking gloves might be a nice accessory. But we are talking about the obvious here: a 42+ watt front end. You know what you're asking for if you decide to get something like this. This is not a light for beginner owners, just like the insanity-class hotwires (back then, 3K+ lumens) were mainly acquired by those with a familiarity of how to feed and tame the beast, or at the very least, were committed to learning how. That having been said, today's insanity class LEDs are much safer, and easier to operate than the risky hotwires of old. To put it into perspective, once upon a time, we were pulling a mere 3K lumens from over 120 watts of power.
Thank you Acebeam: great job on the K60. For a light with so much power, it is surprisingly practical and useable as well.
Thanks for another great review, candle lamp!
I know that this Flashlight blinks at low cell voltage, but oes this Flashlight have under-voltage cut-off? HL
Hi candlelamp,
Do you still own Supbeam K40 (Xm-L 1147 lumens) flashlight ?
my email : [email protected]
Thank you.
I really love using this light for nighttime fishing. However, the K60 low battery voltage indicator is just a major drawback for my purposes. With Thrunite 18650 3.6V 3400mah protected batteries, I am getting 55 minutes on level 5 (3400 lumens) and then the low voltage blinking occurs, and it will keep running strong for another 25 minutes with the blinking feature.
The low voltage blinking feature kicks in when my batteries are at 3.6V which does not seem very low at all.
I am thinking of purchasing Panasonic 18650 3400mah unprotected batteries. Do you think those will help me maximize the amount of time I can get with this light without having to see the low voltage blinking? If I can just get 20 more minutes without having to see the voltage indicator that would be perfect for my fishing trips.
Thanks
candle lamp, have you measured the voltage on your unprotected batteries the moment the K60 started to flash low voltage? I got a response from Acebeam that the low voltage warning is supposed to start at 12.4V. If the 4 batteries are in series, that would mean the low voltage warning should begin when the batteries are at 3.1V. Is this theoretically correct? I am not sure why my K60 starts the low voltage warning when the batteries are at 3.6V.
K60 has no internal charger so it's a non issue.
Great review candle lamp! Thanks 🙂
Discharge is no different than any light.. Series connections, either they connect or they don't.
Just use same type and brand and age and you should be fine.
But that applies for any lithium light, don't mix batteries from different lots of you want to keep things balanced.
Great review candle lamp! I can definitely see this light in my future. Looks to have a reasonable balance of throw & spill.
Among the heavyweights, maybe the most versatile and best bang for the buck!
Well candle lamp,my light arrived today and made up with it . Great build quality and knurling which is better than i thought it would have been. Easily matches the thrunite tn35vn i have(which is a nicely made light). Heat sinking,shaved dome and heat treated bezel are the differences over the standard version along with throw at 230kcd measure by Justin.
Not tested yet(not dark here) fully,probably be weekend now when time allows.
Bezel pic
