R
RCLumens
Greetings to all, posting to see if I can get some input from any other group members on the L30 from Acebeam. I also do have an L16 which has been great. I did recently post on the L16 that it flickers and that it was the cigar ring which loosened up and made contact. After tightening, the problem went away.
The L30 which is the newer (for me) of the two is the version ii with the larger battery. It recently started to do a three flash sequence when on turbo. I read somewhere on the forums that this is a low voltage warning, however in my experience, the light remains on turbo.
Another issue I have is that the battery is too long and doesn't fit into the charger. (Which is a nitecore and says it will charge this battery type...) I have been using the usb to internally charge the battery, but I fear that somehow either the battery isn't getting the full charge, or there's a bigger issue.
Is there a battery charger that the L30 battery will fit into, or any thoughts on the matter?
Many thanks as always!
RC
RC
