Acebeam new arrival ---H40 AA size infinitely brightness headlamp
acebeam
Well-known member
Manufacturer
Acebeam H40 is a simple, compact, lightweight headlamp with tremendous power and reliability.
  • Utilized CREE XP-L HD or Luminus SST-20 CRI98+ LED;
  • Max brightness output 1050lm;
  • Infinitely variable brightness from 20~230lm;
  • Various AA batteries are adoptable;
  • Constructed from aero grad aluminum allow;
Click here for more details
borealis
Well-known member
USA
I have a question about this product -- does Acebeam use the exact same reflector in both, the XP-L and the SST-20 versions?
The XP-L lamp ~3.4mm, but SST-20 is much smaller ~2mm. I believe that using a reflector designed for XP-L would produce a donut hole pattern when used with SST-20. Could you please clarify?
Buck91
Well-known member
Is this supposed to be compatible with 14500? None of my 14500 cells work (all are too long( despite having no issues in multiple other lights.
