Acebeam PT10 Penlight Is An Ideal Gift
gearvita
The Acebeam PT10 penlight is ideally meant for use by Law Enforcement professionals, mechanics, and as a general-use EDC, due to its small size and bright output. This handheld flashlight, though it measures just over five inches long, which is about the same as an average-sized pen, offers an incredible 360-lumen High mode. Compare that with other 2 x AAA penlights and you'll quickly see that the Acebeam PT10 is clearly the brightest of the bunch! This LED penlight is equipped with a Cree XPL-HD LED, which delivers the latest in illumination performance and efficacy. Over time, Cree has developed and optimized their lamps to deliver the most amount of lumen output from the smallest-sized lamp possible. The Acebeam PT10 runs on two AAA batteries, which power the LED penlight for approximately 48 minutes, when in High mode. If longterm use is your focus, you'll be happy to learn that this flashlight can run for 10 hours in Medium mode (30 lumens) and up to 36 hours in Low (3 lumens).
Main Parameters:
LED: CREE XP-L HD W2 high density LED with a lifespan of 50,000 hours
Max Output: 360 lumens ( 2*AAA NiMh or Alkaline battery )
Peak Beam Intensity: 1046cd
Max Beam: 65 meters
Compatible Batteries: 2 x AAA
Working Voltage: 0.9V - 3.0V
Impact Resistance:1.2 meters
Waterproof: IPX-8 standard
Brightness Levels and Runtime:
Mid: 30 lumens ( 10 hours )
Low: 3 lumens ( 36 hours )
High: 360 lumens ( 0.8 hours )
Product Features:
● Durable aircraft grade aluminum construction.
● Premium Type III hard-anodized anti-abrasive finish.
● Toughened ultra-clear glass lens with anti-reflective coating.
● Copper base plate for more efficient heat distribution.
● Orange-peel reflector broadens the beam throw.
● Tail switch on/off push button for one-handed operation.
● Capable of standing up securely on a flat surface to serve as a candle.
There are three colors for options on GearVita - black, silver, and gold. With a small gift-wrapped package box, PT10 is an ideal gift for you to send your family, friends, customers, etc. if you are looking for a compact pen style light that can be used for first aid, other medical and EDC: https://gearvita.com/acebeam-pt10-led-penlight-360-lumens.html
Related products:
https://gearvita.com/fenix-ld05-v2-0-led-penlight-100-lumens-with-uv-lighting.html
https://gearvita.com/manker-pl21-led-penlight-200-lumens.html
