dandism
Re: Actual Lumen Readings by bigchelis in 10.5in Sphere.
BigC, will there be a San Jose area lumen measureing meet? :naughty:
Help Support Candle Power Flashlight Forum
perhaps the rubber pre-colliminator needs playing with. I accidentally bumped it before.
Where did those so-called 630 OTF lumens claimed by the Fenix go?
Surprising that the AW/XP-G R4 and SSC P4 U2 towers measured so low. When I ceiling bounced those and other similar towers, they were all comparable to or brighter than a Malkoff M30. Also, I measured the drive current from the drivers to the LED. To get 170 OTF lumens from an XP-G R4, the drive current would have to be closer to about 750mA (assuming 30% optical losses from the reflector and the window), whereas I measured 1196mA drive current from the SOB1227. Similarly for the P4 tower, I measured 964mA drive current from the SOB1000. The P4 is a U2-bin from Photonfanatic, so it should be up to spec, meaning at least 100 emitter lumens at 350mA. To get 120 OTF lumens, the drive current would have to be around 700mA, again assuming 30% optical losses.
Even Light Reviews measured 626 (obviously VERY close to 630), but then I'm not an expert on the complexities of an IS.
http://www.light-reviews.com/forum/viewtopic.php?f=4&t=122
DANNNNNGGGGGGGGGGGGGG big C, your just going to town on all these readings. Great job.![]()
