Re: Actual Lumen Readings by bigchelis in 10.5in Sphere.
I doubt that Arctic Silver 5 is really necessary. You can save your money and use Arctic Alumina compound or Ceramique.
I tabulated thermal conductivities of the various Arctic XX products
here.
Arctic Silver 5, 8.89 W/m-K
Arctic Alumina compound, >4W/m-K
Ceramique, >5.08 W/m-K
Thermal resistance is given by bond line thickness/(thermal conductivity * effective contact area).
I did a back of the envelope calculation for an LED turbo tower in a KT1. The contact area is an annulus (a ring) with OD ~0.8" and ID ~0.6". Thus, the contact area is pi*(0.8^2 - 0.6^2) = 0.88 sq in = 0.00057m^2. If we use Arctic Silver 5 compound, we have a thermal conductivity of 8.89 W/m-K. If we assume a bond line of 5 mil (0.000127 m), we get a thermal resistance of 0.025 C/W. So it looks like the thermal resistance is essentially nil, meaning you should get good heat flow from the tower to the TH and thus good heat sinking by the TH.
The 5 mil bond line assumed above is probably larger than actual since the LED tower is pressed tightly against the under surface of the TH. However, you could have 5 mil slop in the threads of your pill and in the fit between the TH and the flashlight neck. Regardless, the thermal resistance isn't overly sensitive to the bond line thickness (linear dependence). We could double the bond line (and 10 mils is a big gap) and the thermal resistance will become 0.05 C/W for the above turbo tower calculation. Still negligible.
The thermal resistances for the other compounds scales with their thermal conductivity. Thus, for AA compound, the thermal resistance is <0.056 C/W. For Ceramique, it is <0.044 C/W.
BigC, your setups most definitely will have far more contact area than what I've used here for an LED turbo tower in a KT1. Probably orders of magnitude more. Any minor differences in thermal conductivity for Arctic Silver 5 vs some other magic goop is completely swamped by the huge contact area.
Keep the bond line thin and the contact area large and you probably can use toothpaste.
