Actual Lumens readings in 6" dia. Lab Sphere IS with SC 5500 control - PART II
Re: Actual Lumens readings in 6" dia. Lab Sphere IS with SC 5500 control - PART II
None of the Quark's match the stated output. The ones that do are running higher voltage rechargeable batteries.
Preon 1 - stated 70, actual 63 (NiMH)
Preon 2 - stated 160, acutal 148 (NiMH)
Q mini AA - per 4Sevens this one performs to the stated output on fresh alkaline, which was not tested.
Q mini 123 - stated 189, actual 142 on Big Chelis' 10.5' sphere.
Quark RGB - stated 150, actual 150
I don't think I can hold a manufacturer accountable for a 10% difference when it's unlikely the sphere used by 4Sevens was calibrated to Mr. Gman's or Big C's sphere. The Qmini 123 does appear to be quite off from stated lumens.
It's ok to be disappointed that the mini's are not constant current (as I think many of us had previously assumed).
Btw, the current discussion is here in this thread: http://www.candlepowerforums.com/vb/showthread.php?t=260659
With the Preon I and the battery it comes with, it's 58 to 70, which is about 17% off. Now, it does seem to perform better with an NiMH battery. But if you're going to use that, then what should we expect out of the Mini AA, which is 68 lumens to the stated 90 on an NiMH? Should we expect it to be much closer to 90 lumens on an alkaline? Using the numbers with an NiMH battery (which should perform as good as or better than an alkaline), the Mini AA is 25% off from the stated output.
The Preon 2 is the same case as the Preon I. With the battery it comes with, it's 140 to 160. And after 30 seconds, it drops even further, which you'd expect from the heat, but this only illustrates the discrepancy further (especially compared to an E2DL, for example). The RGB is fine, as the battery is a 3.0 rechargeable (thought it was a 3.7), but overall, it's not a fantastic showing, especially for the Mini 123. 🙁
please note that the preons are tested at 1.5V alkaline batteries, not 1.2V cells.
also, please note that even a difference of 40% in output is barely noticeable.
sometimes, us flashaholics tend to go crazy over mere numbers.....
you are expecting too much out of this class of flashlight and you cannot make a legitimate comparison to the Surefire E2DL and have the same expectations. Its a different class of flashlight both technically and price wise. If we had tested the quarks that take the Alkaline AA's we might have gotten higher readings at turn on but again the voltage and output would sag anyway. You don't buy this class of flashlight for a constant high lumen output. If you want the performance of a E2DL buy it, If you don't want to pay that price well then, welcome to reality. There are the Fenix 2XCR123 lights a plenty for under $100 that work very well and hold a good output in the TK series, there are the EagleTacs that are also good values for the same.
The Quark mini is a $39.00 light running on 1 battery, why do you expect so much? Any light designed on Alkaline AA's should not be given high expectations either. And also you shoud not take any of the measured lumens readings to be 100% accurate or proof of what every copy of that model light would produce. Test 10 copies you may get 10 different numbers. Again, your expectations are simply too high for an otherwise good low budget EDC light.
But even with the 1.5 V cells it comes up short, is my point.
The comparison is perfectly valid. The E2DL is rated at 200 lumens (and we know how Surefire rates their lights). What does it put it out? A little over 200 lumens- even after getting a little warmer. The E1B is similarly rated. Its stated output is 80, and that's about how much it puts out according to your presumably accurate measurements. Since I trust your measurements to be pretty consistent, there's no reason to believe that your measurements with Surefire lights are significantly more accurate than your measurements with Quarks. I certainly wouldn't expect you to be 40 lumens off when testing the Quarks. My expectation is the same- if you are going to advertise OTF lumens, well, they should be OTF lumens. With the alkalines and the Quarks you tested, the output is definitely not as advertised. Disappointing, to say the least, but it doesn't diminish my love for the Quark line.
The expectation is that if OTF lumens are reported as a spec, they are actually OTF lumens. I'm not sure what your expectations are, but my expectation is that specs are reported as accurately as possible if they are reported in the first place. It's one thing to say "225 lumens" but not refer to anything in particular as a marketing gimmick, but when you state you're measuring OTF lumens, you hold yourself to a higher standard, and if so, that standard should be at the bare minimum, met.
I have zero issue with how much or how little light the Quarks put out, and I own several. While I've had some issues with tailcaps, they are still my go to lights and I do recommend and EDC them. My AA versions may not be as bright as an E2DL, but so what? That is completely beside the point and a non-issue.
What is an issue for me (and not an issue more than a disappointment, at that) is that Quark lumen ratings are not actually rated accurately when advertised as being OTF lumens. I don't care if a Mini 123 puts out 180 lumens or 140. What I do care about is if its being advertised as X OTF lumens, it's actually X lumens OTF, and not Y. Again, I'm not sure what your expectations are, but I don't think it's unreasonable to expect OTF lumen ratings to be, well, OTF lumen ratings.
Now certainly there is always a degree of variation and error in not just measurement, but the LED's themselves. Perfectly understandable. However, do you really think that, short of a dud, there is over a 40 lumen range in say, Mini 123 output that would result in two, perfectly good, Mini's producing 140 and 180 lumens, respectively? Quite frankly, if the range of output is potentially that large between samples, I'd want OTF lumens to be reported at its lowest level at the minimum. In other words, if the output of Quark Mini 123's varies between 140-220 (180 plus or minus 40), I'd want the spec to read that, or 140. In other words, I want to get what is advertised at the bare minimum.
Of course, I doubt this level of variation exists in Mini's or other Quark lights, but again, that's not what disappoints me. Inaccurate reporting of reportedly accurate lumen ratings does.
TwitchALot, you have made your point, enough said. You now have the responsibility to complain to 4sevens about this issue, as he is the only person who can really handle your concerns.
Bill
Bill
Correct me if I'm wrong, but you seem to be upset about something I said. What's bothering you?
I don't think any flashlight company reports the "lowest level at the minimum".
With the exception of Surefire I'm not sure any flashlight company underrates their output. Then again, no one else upgrades their (outdated) emitters without publicizing it.
4sevens started the whole OTF lumens thing so they're the only ones that can be called out for it.
Still, then Fenix, Eagletac, Olight, etc should be called out for not mentioning they used "inflated" emitter lumens and all of the quoted lumens aren't actually available. You should take aim at those companies.
Start with Thrunite and their 1st drop-in - 260..then 230?
I don't get what all the fuss about the Qminis is anyways.. Doesn't look like a HUGE discrepancy in numbers.
And I'm not dissing BigC in any way but a few #s on his page look off.
BTW, this isn't the proper way to deal with a customer complaint - read the title of the thread.
Well I'm not sure any flashlight company has that kind of range in their output unintentionally, either. But for the sake of argument, suppose several manufacturers did have wide ranges in output, and none reported the lowest value in that range.
Is there any reason why one company shouldn't start reporting outputs using the lowest value in the range? Is the fact that no one else does it an excuse to NOT be innovative and honest? Hardly.
I'm not familiar with Thrunite in so far as I don't own any of their lights or read any reviews about them, but I am aware of other companies like Fenix stating emitter lumens instead of OTF lumens. And no, I'm not any happier about that. That said, when I get a Fenix (well, already have some, but I digress), I know that I'm not getting OTF lumens, nor is it advertised that way. OTOH, when I get a 4Sevens, I expect to get what's advertised - OTF lumens (same with Surefire, but only out of their reputation). It's a matter of expectation.
What would you call a huge discrepancy? What numbers do you suspect of being off and why? Do you have your own system for testing the output of the lights you suspect for having inaccurate numbers?
It seems to be implied/assumed that I'm unhappy with the performance of my Quarks. As I mentioned, that is not the case. In fact, the interpretation of G's results are what's interesting and in fact, what the thread is about. Also keep in mind that this line of discussion wasn't instigated by me.
Your comparison of a non regulated low budget light to an expensive highly well regulated light is not valid. Looking at the output graphs of the quark mini's shows the output drop in the first 10 minutes as the peak voltage of the battery goes down and also go back up a little as the battery warms up shows its not going to ever be a "constant" output. And to argue a non constant output light should have some guaranteed value is the problem.
In general you are preaching to the guy who created the thread to expose the shortfalls of all these lights in the first place by making actual lumens measurements in a johnny come lately kind of way. You are not covering new ground.
Complaining that the light outputs should be what they advertise in general is a good criticism but nothing new. Again your the guy in the choir preaching back to the Pastor, the virtues of truth. This thread and the original one behind it goes back a lot on this subject and started other threads that cover this subject rather well. We would all like lights that put out what they say if they bother to publish OTF lumens in the first place. However we also have gotten familiar with what reality is. Low cost non regulated lights that don't hold there output as the battery voltage sags simply aren't worth arguing about. So specifically your example of the $39 Quarks should be what they claim because the Surefire E2DL is, just isn't valid. On the other hand you could put in a higher voltage battery and get far more than they claimed if you want to risk possibly shorter operating life or failure, but used in short doses you can get plenty of light out of these things.
Pointing out that a vendor of a $39 non regulated light even claims X amount of lumens in the first place that they cannot hold even if they met those numbers at turn on is valid, but beating the point to death is not. There is plenty of data out there showing the numbers and the light output fall off over time to prove what this and various other lights actually do. Its then a matter of buyer beware.
I'm not sure why you're making this point, as you measured the Minis at turn on (when none of this would be a problem), and they do not match up with the advertised OTF lumens. What difference would the regulation make at turn on using a fresh battery?
What are you talking about? I was using your results, which I assume to be pretty accurate given that measurement standards are few and far between ATM (and faith in you on my part), to realize that the Quarks appear to have a discrepancy between what 4Sevens rated and what you rated. I only expressed disappointment in this fact. How you came to the conclusion you did above is still a mystery to me.
I said it was disappointing, not that it was an issue with me or that I was unhappy with the Quarks. If they weren't bright enough for me, I would have returned them. The fact that I didn't should say something.
Please clarify about how I was "preaching to the Pastor, the virtues of truth." You were the one that stated, "Its a different class of flashlight both technically and price wise. If we had tested the quarks that take the Alkaline AA's we might have gotten higher readings at turn on but again the voltage and output would sag anyway. You don't buy this class of flashlight for a constant high lumen output. If you want the performance of a E2DL buy it, If you don't want to pay that price well then, welcome to reality. There are the Fenix 2XCR123 lights a plenty for under $100 that work very well and hold a good output in the TK series, there are the EagleTacs that are also good values for the same."
It's what got us on this tangent, but it's certainly not my fault. I don't have any issue with the brightness of the Quark series or its performance. Now it seems that you (and others) are simply taking offense to the fact that I stated OTF lumens should be OTF lumens, which is of course, different from not advertising OTF lumens in the first place. Is stating that so offensive, and if so, why to you in particular?
Again, you bring up the amount of light that comes out of the Quarks. What does that have to do with anything? As for my claim, how is it not valid? I'm not seeing your argument. I never claimed a Mini should put out the same or greater amount of light than an E2DL. The only reason I used that example, and the E1B, is because Surefire has X rating, and you got X lumens out of your test, which is not what 4Sevens got with their IS setup. That may be due to a difference in setup, of course, but then again, I doubt you, Surefire, and 4Sevens use the same setup.
So you admit my point is valid. What's the issue, then? Any other point I'm making was simply the result of you assuming that I expected the Quarks to put out more light (E2DL levels) or that I was unhappy with the performance of the Quarks. None of which I mentioned, or is even true, at that. Even now it seems like you think I think that Mini's should put out more light and better regulated light, or that I'm comparing Mini performance to E2DL performance. Once again, that is not the case, and never was the case if you read my posts.
What I was comparing was E2DL performance to E2DL stated lumens, and Mini performance to Mini stated lumens. The end result is that people who clearly love 4Sevens and the Quark series have rushed in to defend 4Sevens under the assumption that I'm attacking them or the performance of their lights, when neither was actually done. The only problem with such a result is that A) I never attacked 4Sevens, B) I love 4Sevens and the Quark lights, and C) I've discussed the matter with 4Sevens and am content with the response.
So, if you and others are trying to defend 4Sevens by stating that other companies don't even rate OTF lumens at all, or that the Mini is not an E2DL class light, that's fine. But wholly unnecessary. As is attempting to blame me for "beating to death the issue" because of assumptions that you made and the discussions that resulted from them.
TwitchALot... you've made your point... at great length, and several times. Your argument is beginning to sound like an endless self-justifying loop, and I think we've had enough of it. Please let's move on, before I start to wonder if you might just be trolling here...
No issue on my end DM51; it's just that I don't like being falsely accused of doing something I'm not any more than the next guy. If my questions weren't sincere I (personally) wouldn't bother asking them.
Just one point of clarification and I want to be done with this issue as well. Regarding non-constant current regulated lights such as the Quark Mini's and others; testing them in general. Normally the practice would be to use a brand new battery or a fresh off the charger battery. However, and this is why I don't like them. At the time I tested them I was not informed of this, just given the lights with batteries. I cannot remember if I was told that the batteries were freshly topped off the night before by the person giving them to me or not. but the light was turned on and off a few times just to check the beam pattern and get it centered in the sphere prior to the actual let it cool down and turn it on "real" test. Thus the issue as to how fresh is fresh on the battery and are we really measuring its best peak turn on value comes into play? Probably not? If I had known that it wasn't a well regulated light I would not have bothered to test it to begin with because you have the issue of how good are the batteries. Then there is the issue of does this type and brand of battery have more sag than another one. Would it have higher peak turn on with a better or newer battery, can't say with a sample base of 1 battery or one pair of batteries as given for the light types in question. I tested each model with whatever battery was given me and wasn't looking to do a whole field and slew of testing as to the best possible performance with every battery brand out there. Especially since they aren't my lights and my time is very limited. This is not a problem with fully regulated lights such as a Surefire E2DL because the output isn't going to droop if the battery if 5% of of its peak charge for example. The only real issue for most well regulated constant current type driven lights is the actual warm up of the LED itself. That is why I say a comparison cannot be made from non regulated lights and how well they do or don't hold their lumens values to those that are regulated and do. Its just not a fair comparison in that respect. Why vendor's choose to publish numbers for a light that isn't going to hold it past the first 1 to 5 minutes based on current draw from the batteries is a whole other mystery and issue, but I am not going to rehash it again.
Just for the record I personally don't own and Quark lights and would not buy any of the ones that are not fully regulated and am not a "defender" of such. That does not mean they are not good lights for what they are in their price range, I EDC a Malkoff MD2 with M61. I tried to provide points of data to people who asked and could get a light to me at no cost to myself other than test time. I'm done.
your happiness with a particular product may be inversely proportional to how much you really know about it. (for all you guys saying man that is so true about my wife, can't help you there either:nana🙂. goodnight
I've never seen a single HDS / Ra light that tested at less than the advertised OTF lumens.
A great deal of the problem for less expensive lights is that they can test a top-binned outperforming LED in a production light in an IS, get the OTF lumens, and advertise them. Certainly since the lights coming off of production probably aren't tested beyond ensuring they light up, all the cumulative variability in the entire drive circuit, particular emitter, etc. is going to add up and almost inevitably result in a light putting out less OTF lumens than the outlier spec model. I can't put a whole lot of blame on this type of maker, other than wishing they'd say "150 TYPICAL OTF lumens" rather than a more definitive and inaccurate "150 OTF lumens".
So this is one way by which you can get 20% less OTF lumens than advertised.
Certainly some makers have ridiculously inflated OTF numbers or use numbers for a bare emitter - not mentioning any names here, since we're all aware of many of them, and that's nothing but complete deception and false advertising, in my opinion. (most mass market lights go this route).
There are makers like Surefire who may not individually test each light for output, but they underrate their lights by enough that even a poor performer will meet specs, and by lottery an overperformer may greatly exceed the published spec.
A fourth category (probably the least common) is a maker like HDS / Ra, which individually calibrates each light to ensure you're getting the published OTF lumens. Even an "underperforming" emitter is still guaranteed to get you a certain OTF lumens and runtime. A higher performing emitter from the chosen bin is still only going to get you the same published lumens, but the bonus is added runtime. Of course, HDS also uses constant a Power driver...
Thanks MrGman for you helpful infomation,you must spent long time for this thread ,beyond question this is not a easy job.Good job :thumbsup:
Yes,thank MrGman for your great test and very helpful info:thumbsup: ,this is not a easy work really .i just read another great thread posted by bigchelis,thank MrGman for your help to that thread:thumbsup:.
thank MrGman for your great test and very helpful info,collection is not a easy work...Really helpful to me.:sssh::sssh::sssh:
Danky
