old4570
Price from Ali / Less than $20 Oz bananas to my door
HRC - 55/50 ( 55HRC bites / 50HRC skates )
Bevel - 16 degrees per side ( Factory angle )
Rope slice = 650 slice fail
Edge = 80Grit Grind on the wet stone grinder / knife sharpener ( Factory edge not tested - Some what FUBAR )
Edge degradation was felt from 500 slices .
Spine lightly ground for Bushcraftyness .
Slicing rope , the gimping on the spine was a pain giver ! @ 250 slices I had to go to the Pain Reducer ( Leather Rope Glove ) .
Pain also when scraping wood .. The longer you scraped wood the more Pain U were rewarded with !
With some light grinding of the spine , the knife was satisfactorily bushcrafty . ( Except for the pain ) .
Hmmmmm , Good and Bad ! Decent performance , above average pain and suffering with extended use .
Any knife that causes PAIN when used , is not a knife you want ! For occasional use the AD15 is probably ok , but for a decent cutting session = Hell No !
Looking for a working knife , look somewhere else .
Video Soon !
Video Posted on VEOH
