Anglepoise
Additional \'O ring lube information for our lights
As anyone who has read any of my previous posts knows, I am anal when it comes to smooth operation of threads that have to move for switch activation.
To get good and smooth operation there are a number of factors.
Yes the threads need to be accurately machined and the 'O' rings registered correctly with the correct clearance.
However it is this 'O' ring clearance that causes us some grief. Its a compromise between water exclusion and smooth turning for easy switch activation.
Designers do their best, but you can have the smoothest turning threads but still have a switch that is stiff to turn easily due to the lack of 'O' ring lube or the wrong type.
90% of manufacturers of 'O' rings recommend some sort of silicon lube and in many cases this is cheap and works well.
However it does not work so well for situations when the 'O' ring has to move,as in Aleph and PD threads.
An application of silicone grease seems to work for 24 hours and then it starts to dry out and gets stiffer with time.
I have found Teflon plumbers tape to work well on threads so I decided to try some Teflon grease on the 'O' rings.
Teflon has no solvent so it can not be dissolved, evaporated or washed off. A very small application on any 'O' ring gives amazing results.
So for you enthusiasts and collectors that don't use a light every day , check out this stuff
Link to Teflon grease
Its expensive, but so are all good things.
Oh yes.....I have a set of pure Teflon 'O' rings on their way for testing and will report back on these when I have had a chance to evaluate. An 'O' ring that never needs lube, might work well in our aplications.
