Kenom
Re: Adjustable 10A linear constant current driver
As long as the bike is on, it will be moving faster than 10mph. I can honestly say that I've never ridden the bike slower than 15mph. Unfortunately, the bike has a LOT of torque and I cannot take off without it instantly speeding past 10mph in the first second or two. The Yamaha V-max is known for it's power.
Your concern is however noted. I can't imagine using more than 2 Lights on this bike though.. just seems like overkill. Any way to add additional lower powered LED's into the mix? Say like 2 XM-L's?
How about a Peltier affixed to a heatsink with the driver on the opposite side? I have a Peltier pulled from a C@sio Projector that had a SST-50 red led mounted onto it. I used the projector to harvest for blue Laser diodes.
Sorry, not meaning to clutter up your sales thread with discussions on lights and such.
Unfortunately, the heatsink isn't the only problem. If you run one LED on an IS1006-0820, the driver will dissipate about 80W. Short of soldering the FET directly to the heatsink (which would then require that you electrically isolate the heatsink), there's no way to get that much heat out of the FET and into the heatsink without unacceptable temperature rise. The practical limit is around 30W, which is about what you get running three LEDs in series.
