stephan2148
- Joined
- Sep 18, 2007
- Messages
- 35
Hi, just bought an advance auto 3W luxeon 2C. I have modded the energizer 1watt rechargeable by just shorting out it's lowish resistors inside.
The energizer is noticeably brighter then the AAP3W. Since using rechargeable nimh, the run is nice and flat, but for a half four only.
The energizer package said lumileds. THis was the target $20 clearance special. It is built Very well.
I measured 1.14A at the batteries and 3.55V to the led from the energizer (it is a 3.6V nimh driven directly), and since there is no stepup, I assume 1.14amp to the led also. Driven direct, I get about .5h of bright light which is a little lame though.
Interestingly, I measured also 1.14A at the batteries of the AAP3W and 3.23V at the led. I can only assume the led is getting lower current at the led than the energizer since it is stepping up the voltage and then must use some of that battery current (is 85% eff. typical maybe).
I measure 3.15V from the batteries unloaded (the alkalines from the package).
Anyway, I was a little disappointed in the AAP3W to the modded energizer, but I do have a seoul w42180 z-power coming, maybe it will be better. It was going into the energizer, maybe not. Also a cree from cree.com as a sample
Maybe I will hack the switcher in here to get more out of it also, it all comes apart, just gooped up with heat grease.
edit- no luck on the boost circuit, it is probably maxed out. 10KHz ish inductive switcher. Output to the LED is 350ma measured, 1.14ma sucked from the batteries.
-edit Using nimh, no better results.
It is just not enough current for my taste.
I suppose I need a 1A driver or better to approch the energizer blinder.
I need to see a refrence 'bright light' to klnow what all this cpf fuss is about. Are there really such bright lights I am hearing about? I'll continue modding until I impress myself. Rayovac search next around town. One of these days it will show up.
