I'm looking into making my own rechargeable light with a magnetic tail cap as the contacts, but I've run into conflicting information on the mechanical side of things.
I'm using the OLight S10R light as a basis for discussion.
What I'm trying to accomplish is a way to mimmic how the OLight works in terms of the magnetic charging tail cap. It's pretty obvious that the middle pin on the ring is negative, and I can only assume that the positive side is going through the actual body of the light because it doesn't look like there's any other way possible. I've always been told that it's a bad idea to use the body as the positive side. I also assume that the outside of the light is coated with an insulated material, but I wanted to get the thoughts on others that have experience making their own rechargeable lights.
Thanks all.
Thanks all.
