InHisName
If you have been there, done that with DIY cell replacements of laptop battery, then read on and advise. Below is link that got me to making this message that I have been thinking of doing for last few weeks.
http://www.candlepowerforums.com/vb...50-3100-mah-vs-2400-mah&p=3945669#post3945669
I have4 BM T21 batteries, 2 dead, and 2 nearly dead. I've been planning to put some of those new NCR18650's into it. After much reading it seems that that could be a big waste of $$$$. I saw a chart on panasonic's site that showed the MAH curve vs voltage. Seems the 2200, 2600, 2900, and the 3100 have about the same MAH from full to as low as 3.4v. The bigger ones run to lower voltages for the greater capacity.
I installed a battery monitor in my laptop and when it got to less than 4%, it had just dropped to 3.47 which inicates that I'm not sure which cells would really do the longest hours/minutes. For a battery's cells to go from 4.2 to 3.45v isn't near the full capacity but is all that comes from the battery as it sits. So 3600mah or 4400mah are neither very real.
So the multi-faceted question I have, if you've been there, done that is: Should I even bother with DIY cell replacement ? Or just blindly order from lowest price on eBay from some chinese builder ? If I were to do it myself, which cell size gives the most REAL minutes run time ?
---- Is there some way to change the laptop battery pack 4% point from 3.47 to 2.8 ? Then maybe the 2900 or 3100 might be more useful.
