Hi.
I'm new to forum use but basically I want to use a laser as a range finding aid on my air rifle. The basic idea is that you mount a laser pointer above the telescopic sight. The crosshairs of the scope and the dot of the laser are both zeroed at a chosen range (say 35 yards). If the laser dot aligns with the crosshair you know the target is at 35 yards. If the laser dot is above or below the crosshair you can get a good idea of the yardage to target by seeing how far (using the mil dots on the crosshair) above or below the dot is.
To get to the point. Some laser pointers are available commercially for this purpose but they are usually red. They don't have a very good dot brightness so cannot be seen easily in daylight. generally they do not have a very focused dot (most quote sizes of around 4 inches dot size at 100 yards). A Greenlaser is available from a company called Beamshot and this has a dot that can be seen easily in daylight and the dot size is 1.75 inches at 100 yards. Unfortunately it is prohibitively expensive!
Does anyone know of a laser pointer or module that gives a dot that can be seen in daylight, that is fairly small in size (i.e.dot around 1.5 inches at 100 yards), that can be placed inside a tube so I can fix adjusting screws to zero it vertically and horizontally?
Thanks,
Ian
Thanks,
Ian
