I previously had the G2L, and now I have just bought a G2Z.
They both have a similar trait, in that the tailcap is a lot easier to rotate (either direction), needs a lot less pressure applied to move it, than the metal equivalents, 6P etc.
In fact, with the G2Z, it is so smooth/loose that a small amount of light handling, in and out of a pocket a couple of times for example, is enough to have moved the tail either way without me even knowing.
I assume (and we all know what that is the mother of.....) that having a larger/fatter o-ring will solve this, and make the tailcaps tighter. So, can anyone please tell me the size of o-ring to use? Either the fatter option, or just the measurements of the Surefire one and I'll try to find a slightly larger one.
I do actually have a few assorted o-rings which would be about the right size, but most seem thinner than the one on the G2Z which would make things worse I suppose.
Thank you
Thank you
