DHart
Seems I just can't find a resting place when it comes to acquiring new lights. And I'm finding that there are some true bargain lights that rival lights 2x, 3x, 4x the price. The Akoray K-106 is one of them! A gem of a find in the world of flashlights.
The latest one to arrive (just today) came in from DX in Hong Kong, the Akoray K-106, featuring a CREE XR-E Q5 emitter.
Input Voltage/Powering Options
Runs on anywhere from 0.7v - 4.5v; so you can feed it an alkaline, lithium, NiMH, or 14500 Li-Ion. The K-106 has 3-modes, each one programmable to any desired output level from high to low, or blink (varying rates), or strobe (varying rates), or SOS.
Build quality
The build quality is excellent. Threads are square-cut and very clean. Body is THICK (strong) and the bore is evenly centered. Double o-rings at the head mount. Threads were not lubed, but with the addition of a little Nyogel, threading is very nice and smooth.
Switch
Switch is a recessed reverse-clickie (so it can tailstand) and not at all likely to turn on inside a pocket. The switch requires pressing via finger-tip as it's fairly deeply set, although with a protruding boot replacement, it could be thumb press-able.
Modes
I'm not much of a fan of strobes or SOS generally, and pretty much never need a "Tokyo (or Shenzhen) light-show" from a flashlight. But I do like having strobe/SOS available if needed, so it's really nice to not have them in the regularly-used modes - that is if you don't want them there - they can be if you do!
Programming
I programmed mine (quick and easy to do, using BessieBenny's guide) to be simply three levels of output: high > medium > low. Though it could be programmed low > medium > high, or high > strobe > Low, or blink > high > SOS, or low > high > SOS... or any of a huge number of possible combinations... you get the idea. This is truly an incredibly versatile UI, especially considering the price!
Output
In a word: AWESOME! On high I recorded an EV of 4.8 in my standardized ceiling bounce test. This is virtually indistinguishable from the output level of the D10 R2 on 14500 and a Solarforce L2 R2 3.7v lamp driven by an 18650!
For reference, here are readings in my ceiling-bounce testing from other well known AA size lights:
Nitecore D10 R2 = 14500 Li-Ion ======= 4.9EV
Solarforce R2 3.7v lamp = 18650 ====== 4.9EV
Akoray K-106 Q5 = 14500 Li-Ion ======= 4.8EV
Romisen RC-N3 Q5 = RCR123 Li-Ion ===== 4.6EV
Liteflux LF3XT = RCR123 ============ 4.5EV
Lumapower ConneXion X2 = 14500 Li-Ion == 3.7EV
Akoray K-106 Q5 = Eneloop AA ======== 3.5EV
Lumapower ConneXion X2 = Eneloop ===== 3.4EV
Current Draw
Current draw on HIGH with 14500 is 1.1 amps. Clearly, on Li-Ion, the Akoray blows away the ConneXion X@ in output. And the ConneXion, being a three mode light - though NOT programmable - is a good comparison to the K-106. The AKOray at $20.89 (including shipping!) is half-the-price of the ConneXion X2 and blows it away in output, versatility, utility on Li-Ion. On an Eneloop, the output of the K-106 and the ConneXion X2 is close. Output levels can be changed while the light is ON by a soft press on the button, as opposed to the ConneXion X2, which must be turned off in order to select a different output level, then back on again.
No idea on runtime comparisons at this point... refer elsewhere for info on that.
Beam Color
The beam is nice; color is a very clean, cool-white beam as compared to the yellowish tint ConneXion X2 and D10 for example. Beam is a little ringy (very softly), but not bothersome, nor noticible on real-world subjects. It's a bright sunny day, so night time throw testing and beamshots will have to come later.
Finish Color
I should note the color of the finish on this light. It's gorgeous.. a satin-finished bronze color. I like it a lot. With this bronze color and Solarforce's new gunmetal and sand finishes, black flashlights are looking a bit boring to me lately. It's nice to see some flashlights in beautiful tones besides the same-old same-old black.
Summary
All in all, this is an incredible value at $20.89 including shipping..... a highly recommended AA-size light! (And I'd gladly give up my ConneXion X2 before giving up this Akoray... not even considering the K-106 is half the price of the ConneXion X2). I'm not aware of any other light with this potency and versatility in output range and powering choices at even 2x the price.
Here a link to some info provided by BessieBenny - which supported my decision to order this light.
http://www.candlepowerforums.com/vb/showpost.php?p=2895765&postcount=333
Shipping time was 10 days from DX in Hong Kong to my mailbox in Washington State. Best $20.89 incl. shipping I've ever spent on a flashlight! :twothumbs
Build quality
Switch
Modes
Programming
Output
Current Draw
Beam Color
Finish Color
Summary
