Aleph 3x XPL build.
vestureofblood
Well-known member
Missouri
HI all,
This gem belongs to member AndyF. He requested that I upgrade the light engine a bit.
The host.
The factory pill was small and used a 15mm driver which he said he did not like, and neither do I so the old pill was replaced with a spacer.
With that done its time for a new engine. A copper pill and mcpcb.
Some 3D tint XPLs
And shazam, were all ready to play!
I thought it best to keep the contenders in this shootout in the same class. For those of you who are not aware the Aleph head is actually e series compatible.
So, what to compare to?
On the Left we have a factory Surefire L1. In the center Fivemega incan. And on the right Tri Aleph.
L1
FM
Tri-A
In total the Tri-Aleph is boasting 1700+ OTF lumens ( not bad for an e-series huh). When I used the equivalent of a zero resistance tail cap on it, the output rocketed up a few hundred more from there too.
Thanks for watching:popcorn:
archimedes
Moderator,
Staff member
CONUS, top left
Wow, nice build .... That heatsink and battery contact is ridiculously awesome (!)
Is that single mode ?
What voltage, and battery(s) ?
vestureofblood
Well-known member
Missouri
nice. can you make more for the same 38mm head?
Ya, I would consider a run if there is interest.
It has DrJones guppy2drv for the UI. 24 groups, but currently set to 2 mode.
Its a single cell organism. One 18650.
easilyled
Well-known member
Middlesex, UK
Also interested. I have some TB Aleph-3 tribute heads in Ti that would look great with these.
2 questions:-
1) the module presumably drops in from the top of the head and then screws down until tight?
2) is there an o-ring seal under the glass window?
vestureofblood
Well-known member
Missouri
Yes the pill threads in from the top, then the optic is placed. I added an o ring to this one, but the glass sat down on it first, then the ring.
vestureofblood
Well-known member
Missouri
Ok, here is where we are at with this. I have finally caught up enough on light building that I have time to consider new projects. If someone in the USA would be willing to loan me their aleph I will take another look at this to see if a production run is possible ( no promises yet).
If you have an unmodified aleph head and body you would be willing to loan me and your in the US please just let me know and I will get rolling on this.
vestureofblood
Well-known member
Missouri
Awesome. Thaks Andy and Dirty wage guy. I have sent PM to Andy, if he has all the parts I need I will borrow his. If not I will shoot you a PM DWG.
easilyled. Yes, I think that thy would increase the range a bit. There are a few obstacles I will need to clear before committing to a run of these, but if we do it I will check and see how various emitters work and get some numbers posted.
