LED Zeppelin
Left to right:
1) Early JiL CR2 1.3W #242 with Cab (14500 extension tube). LE is a FluPIC T-bin Lux III. I've also added a clip to the tail of the Cab. The tapped holes do not go into the battery compartment, just the lip of the tail. $125, $100, $90, $80 *SOLD*
2) Vintage 3" SFTH light, before any engravings were put on the tubes. Not sure of the model but it appears to take a rechargeable cell since both contacts are made at the front of the cell; the rear is a plastic push button with no contacts. The head collar is not compatible with C series tubes, the threads are Acme style with square shoulders. Lamp assembly is included and assumed working but untested. Included is a new TnC adapter which allows the head to be used directly on an E series tube. Anodizing is a perfect match. There are some pinholes/scuffs in the finish of the head and some minor scuffs the bezel and tube, but no dents or gouges. $225, $195, $185 *SOLD*
3) Ti Peak Carribean engraved "CIA Aurora/Mach7". Stock Seoul with a modded McR18S. Beam is much smoother and artifact free. The reflector centering ring was transferred to the McR18S as well for a perfectly centered emitter. I also installed a mineral glass lens and the dimensions worked out perfectly so that the bezel is flush with the end of the head. Original reflector included. As delivered the threads were very gritty. I spent some time lapping and polishing the threads and the are much smoother and easy to operate one-handed. $135, $115 *SOLD*
Priority shipping included in the US, overseas add approximately $10 depending on method. Standard selling rules apply.
