I just got my Alladin Power Hand Charger and was totally surprised at how well it works as an emergency flashlight.
First the charger. It is a comfortable, ergonomic hand crank. Yes it is plastic but it feels solid. The gearing inside does not slip when cranked like other hand cranks I have tried and it is reasonably comfortable to use.
I have not fully tested it as a cell phone charger because my cell phone is fully charged but I see no reason why it won't work.
Now the Amazing part! It comes with a little LED flashlight that plugs into the hand charger. It is about the size of a Photon but round not flat. It has a small hole which you could probably run a string through it to hang it around your neck. It weighs about the same as the Photon, about 6 grams.
It only takes about 10 to 20 quick cranks on the hand generator (about 10 seconds) to fully charge up the flashlight. Then you pop it off the charger and it gives reasonably bright light for 1-2 minutes.
About half the brightness of the Photon but a more intense beam so you can see it in the center of the Photon beam.
After its initial brightness dims IT JUST KEEPS GOING!!! I was reading in total darkness with it long after 5 minutes.
It slowly dims over time but I was still using it to read my watch after 30 minutes!! At that point it is about the brightness of a Pal light in the always on mode. I can't tell you how long it will run at that brightness because it is still glowing after 40 minutes now.
Keep in mind this was after cranking for only about 10 seconds!!!
I believe that this is what you guys were trying to achieve with the Emergency Flashlight project and more. Once charged, this thing is so tiny you can hold it in your mouth to perform tasks.
There is also a little voltage regulator that plugs in and about doubles the size of the little flashlight but extends the run time a bit more.
Well, I just looked at it and it is still glowing after 45 minutes!!
Here is a link to buy it for $19.99 less than 30% of the retail price. I just ordered 2 more. I figure you could charge up several of these little lights in under a minute and have several times the light output.nullAlladin
I asked and they have about 80 of them left.
