Light Sabre
I bought one of the Mobile Chargers today. The blister pack smells like ammonia on the outside and turpentine on the inside. The charger itself smells like turpentine, but I only notice it when I got less than a foot or two from it, and it wasn't too bad at all. The warmer (longer it runs) it gets the further away you can smell it. Seems to work like a charm so far. Doing some tests on it to make sure it's on the up and up. So far so good. Definately 4 separate channels. Battery temps were no higher than 125F. Had 3 batteries on the charger. 2 finished early and 1 finished a long time later (it's a suspect battery). The right off the charger voltage for the 1st two was 1.41V. The suspect battery (last to finish) was at 1.45V. So it doesn't look like it will overcharge a battery. If I remember right it charges at 500ma and goes into trickle charge after that at around 10-12 ma or so. Will see how it does overnight and if I don't seen anything wrong or suspect about it, then I will go buy a couple more.
