My flash light(UltraFire WF-502B XM-L2) started to output with less brightness than it's usual.
I dropped it from about 1.2 meters and it hits the street with it's head( check the photo), the part of the head - surrounded by the red line , is a little bit bended. There is no other visual damages.
That flash light has 5 predefined modes - hi/mid/low/strobe/s.o.s. and currently they work the way they should be, only the output is significantly lower.
I checked the battery with a voltmeter and it showed 4.08V , so most likely be the battery is OK. Is that test is enough to say that 18650 battery is ok or I should do something else?
If battery is fine I assume my next step is to test the bulb. May be some part that handles voltage control is damaged. Is there a reliable way to test the led emitter , driver or I should leave this and just take a spare part ?
