Angler _ Cree Q5 _ 6V Camping Lantern Battery Hook
Wurkkos
LITEmania
Seoul
i will open a sales thread at mp.
XR-E Q5
FRC19mm reflector
B270 Glass
AMC7135 IC
Low, High by Toggle with rubber cap.
6V 4R25(4FM)
You can use Fenix's diffuser tip
High mode : F1.8, 0.5", 20 meter, White balance : Auto
Left : Angler, High-mode Right : D-mini Q2
regards
warren,
F1.8, 1", 40 meter, White balance : Auto
LITEmania
Seoul
i just finished laser engraving and got home
will update tomorrow at work with new picture.
low is 300~330mA ; high is 900mA
this is just for 6V lantern battery usage.
light head is water proof
but the hook/neck is mere splash proof.
runtime (continuous test with fresh 6v, Rocket)
low : 17 hours and go off without any alert.
high :
- 8 hours run at high mode
- and drop to level of low mode and last for 3-4 hours
- and drop to lowest brightness. (we know the 5% mode of typical 3watt flashlight recently.) and run another 10 hours (or more)
- and well....it never died
- so i trash the battery and stop test.
warren,
LITEmania
Seoul
forgot one tip....
One can install LumaPower D-mini Bezel and it fits Angler's body (although the stem(neck) of Angler is not strong for the heavier weight.)
also... you will need a self made insulation shield
to prevent the shot circuit between
the exposed XR-E's leadframe and D-mini's metal reflector.
warren,
CanadianEh
Thanks for posting the sales thread. This looks like a really interesting light concept, unfortunately just not $50 interesting. :shakehead
