Z
z_AVInstaller
Guest
I am looking to purchase a nice LED flashlight for work (call it home inspector to make it easier). I frequently go into unlit basements and need a strong bright light.....a nice tight beam of light helps, because I frequently point out issues to the homeowner, and almost use the light as a pointer at times, but this factor probably does not matter all that much since the things I am pointing out are usually not any further than 20 feet or so. There are times where I need to light up some long areas in a dark crawlspace as well. I would prefer an 18650 light, but not completely necessary. I would like to carry it in my pocket, but again not completely necessary (comfortable in hand or jacket pocket also fine). I would like the ability to have a very high setting (even if I dont use maximum setting in the basement) I do love the configuration of the Sunwayman M20c by having the magnetic ring to select brightness, and the clicky to activate etc, but again, does not have to fit that mold if I find a light I like. Having a very nice finish/craftsmanship would be nice, including a cool factor if there was any, afterall these are functional gadgets for adults. My price range is $75-$250. Runtime is great, but I will always have batteries on hand when dim. It would be nice to have a regulated model that keeps brightness somewhat constant until failure, but not important.
To put things in perspective, I am currently using an LED LENSER from home depot with 3 AAA batteries, but that doesnt cut it anymore.
I have been all over the charts with what I have looked at, but these are some that have caught my eye.....
-MICROFIRE Explorer TL3 (barely any info on these in this forum) but is on the nice beefy side. I like the max brightness, and like that the deflector is same size as rest of flashlight. For some reason, I am addicted to the look and mystery behind this light.
-SUNWAYMAN M20c and M30r (love the selector rings). M30 a little large to pocket, but if great performer, I dont mind. M20c seems to be best of both worlds
-LUMAPOWER D-Mini VX ULTRA .....I am intrigued with this flashlight, that is all I can say
-JETPOWER JETIIIM, RRT0, RRT2 etc
-SUREFIRE E2D and LX2, but all models dont seem to like rechargeables...
as you can see, I am all over the charts with what I have looked at, sometimes even form over function, but that is only natural.......sorry for the long winded post, but I figured more info was better than not enough
- Thanks for all/any info help!
